Mech roller lifter?
https://slantsix.org/forum/viewtopic.php?t=41016
Page 2 of 2
Author:  Polara1974 [ Thu Aug 26, 2010 10:42 am ]
Refloating this thread.
I have found out that the cams are still available, they are made of billet steel and they cost around ARP 2500/3000 (circa USD 625 / 750) not cheap at all.
The cam should be ground and then it should be re-hardened and re-straightened. To produce the cam a very important fact is the roller diameter, because that will affect the way the roller lifter follows the cam.
Here they used Isky roller lifters, so there you should have a wide variety of options. To solve the problem with the link bar between the two lifters of the same cylinder the machined kind of a half-moon in between the Intake and Exhaust lifter bores to make room for the link bar. The connecting bar was placed facing the bores.
Couldn't find the exact Isky part # for the roller, maybe latter.
Any further info I can find I'll post it here. Or if you have any specific question that you would like me to address, be my guest!
Also about oil/pump vs cam gear fairlure one way to solve this is to use a thicker cam, this way we can avoid the cam moving up & down at high RPM. I wanted to mention this since, as far as I read I couldn't find someone talking about thicker cams blanks to avoid this problem.
Regards! Martin
Author:  Joshie225 [ Thu Aug 26, 2010 1:11 pm ]
Martin,
Thanks for posting the roller cam info. I may go with a roller in the second Bonneville engine. The first 'cheap' engine already has a flat tappet cam ground on one of the thick cam cores. The base circle is pretty much flush with the shaft itself. I should post pictures.
Author:  Polara1974 [ Fri Aug 27, 2010 5:52 am ]
Martin,
Yes, thats the way they made the thicker steel cams here too.
Page 2 of 2 All times are UTC-07:00
