| Battery relocation--suggested route for positive cable? https://slantsix.org/forum/viewtopic.php?t=41272 |
Page 2 of 2 |
| Author: | BUCKET 636 [ Mon Nov 29, 2010 6:21 pm ] |
Quote: in my car I have added "the big 3" battery + to charge terminal on the alternator. - 4 guage or bigger with an apropriate size fuze in the wire to prevent electrical meltdown incase the voltage regulator malfunctions. Would running a wire as you have suggested counteract any fused wires/fusible links ? The wire in my 1965 Australian Valiant runs like this: Battery + to starter solenoid, Starter solenoid (via 50 amp Maxi fused wire)to starter relay, Starter relay to ammeter, Ammeter to power circuit. Cheers Greg |
| Author: | BUCKET 636 [ Mon Nov 29, 2010 6:26 pm ] |
Quote: You will lose voltage through those old bulkhead connectors. I bypassed the heavy current leads in the bulkhead connectors years ago and wired the car more like a modern auto with relays and fuses under the hood. Sam My 1965 Australian Valiant doesn't have the bulkhead connectors,the wires from the starter relay run straight through the firewall/bulkhead to the ammeter,the same with the alternator wires. Cheers Greg |
| Author: | Josh P [ Tue Nov 30, 2010 10:26 pm ] |
Quote: Would you have to remove the original wire from the alternator to the ammeter circuit in a 1965 Valiant ?
You could but its probably not necessary since alt. to battery+ is likely the be the path of least resistance.Quote: Would running a wire as you have suggested counteract any fused wires/fusible links ?
No. The fusible link(s) aren't between the battery and alternator (correct me if I'm wrong).It should be noted that, that its likely that the suggested wiring of alt. to battery+ was meant to include the voltage regulator somewhere in between. Also, I think the more modern wiring Sam mentioned mostly refers to the removal of the bulkhead connectors to be replaced with something more elegant and with a lot less resistance. Sam would you please share your upgrades in a new thread and maybe include some photos? I'm sure one of the moderators would love to add more links in the electrical FAQ. |
| Author: | BUCKET 636 [ Wed Dec 01, 2010 1:01 pm ] |
As the 1965 Australian Valiant never had any fusible links/fused wires in their circuit,i have added a 50 amp fused wire between the starter solenoid and starter relay (as per diagram) which connects at the same post on the solenoid as the battery + cable. I was told not to connect/run any 12V fused power wires from the battery + terminal as this would counteract the 50 amp fused wire i have installed and to run any 12V power from the starter relay where the fused wire connects. This is why i asked the question about running the proposed wire(as per diagram)to the battery + terminal. What i don't get is that all the wires are connected anyway,ie,battery positive cable is connected at the starter solenoid terminal to the 50 amp fused wire which in turn is connected at the starter relay terminal to the ammeter circuit. So wouldn't this mean it was one complete circuit anyway ?
| Author: | Josh P [ Wed Dec 01, 2010 2:56 pm ] |
I believe the correct location of the fusible link should be from Batt. + to the starter relay... and if you had wired it like this there would be no issue. |
| Author: | Romeo Furio [ Wed Dec 01, 2010 4:11 pm ] |
| Post subject: | Battery |
To Optima Jim, I have been using a 2000 Honda CRV battery because of its small physical size and it is plenty powerful to start my slant for 2 years now. Is Optima making a battery for the Honda ? |
| Author: | BUCKET 636 [ Wed Dec 01, 2010 4:30 pm ] |
Quote: I believe the correct location of the fusible link should be from Batt. + to the starter relay... and if you had wired it like this there would be no issue.
If you look at the wiring diagram,the battery + cable goes to the starter solenoid first,then to the starter relay.This is how it is from factory.Every other AP6 i have seen is wired like this as well. |
| Author: | Josh P [ Wed Dec 01, 2010 8:40 pm ] |
The order doesn't matter all that much. You could put the fusible link between the Bat. + and starter relay or to the starter (although the starter draws a lot of current and could bust the fusible link pretty often, I'd opt for a second, unfused, cable to the starter). However, with the fusible link between the alt. and batt. you're only protecting the batt. from over-current. If you have a fault in your wiring you might still fry some of your components (like your ammeter). |
| Page 2 of 2 | All times are UTC-07:00 |
