Is there a cheap posi out there?
https://slantsix.org/forum/viewtopic.php?t=41762
Page 2 of 2
Author:  Sam Powell [ Wed Sep 08, 2010 7:38 pm ]
You can get a complete 8" center section with everything new (incl truetrac) but the case and the yoke for $1000. It's $800 for a new trac loc ltd slip (clutch type).
Seems like just buying a suregrip for you 8.25" axle would be by far easier and cheaper. You can likely buy with new bearings pressed on and install it yourself - no need to remove pinion and only need to set backlash+side bearing preload when you're done.
Thanks for all the tips Lou. I figured if anybody knew about this it would be you. Would that be from the dealer, or aftermarket?
Sam
Author:  Dart270 [ Thu Sep 09, 2010 5:11 am ]
Look at Ebay and Mopar shops like manciniracing.com for the 8.25 SG. Rick Covalt had an idea of where Ryan got his??
Author:  Sam Powell [ Thu Sep 09, 2010 5:28 am ]
Ryan says that guy is not posting his ad any longer. I have some idea where to start looking when if and when I want to do this now.
Sam
Page 2 of 2 All times are UTC-07:00
