It is currently Tue Nov 24, 2026 6:05 pm
PostPosted: Tue Sep 21, 2010 4:55 pm
If the water isn't from condensation, then the only way for water to get into the oil is from a blown head gasket or a cracked block or head.
PostPosted: Fri Oct 01, 2010 9:30 am
Update:
I began working on the van. Turns out the oil was just really bad, there was no water in the oil it just looked like water.
The motor has no leak. I moved the van using the starter motor, I had added a fuel filter, the filter connector was loose and when I turned over the starter the fuel pump pushed the gas through which was leaking over the motor causing an oily mess below.
I have changed the oil, the car is running fine, but it still runs hot. Working on that.
Thanks for all your help,
PostPosted: Mon Oct 04, 2010 9:05 am
Greetings,
As a veteran of these vans, I think I MIGHT be able to help with your overheating issue. First, are you looking at the gauge, or are you REALLY overheating? The reason that I ask is that the stock A100 temp. gauges are calibrated from 100-212 degrees. That being said, 166 degrees is the true center of the gauge, and the P in temP is about 195 degrees. Just a thought, but you MIGHT be chasing something that doesn't exist.
Hope this helps.
PostPosted: Mon Oct 04, 2010 9:23 am
Update:
Yay! :D
PostPosted: Mon Oct 04, 2010 12:16 pm
Check to see what thermostat your running. Im sure it's very hot in Mexico and I wouldn't be suprised if someone put a 195 thermostat in there. A 160 will help. :wink: And while your at it. pull the head off and make sure your water-jacket isnt blocked by the head gasket, or anything else there.
Tyler, 19
72 Dart Swinger /6T
PostPosted: Mon Oct 04, 2010 4:37 pm
With all due respect, I don't agree about the 160 thermostat. Before you pull the head, you should at least get an accurate temperature reading. If it ain't broke, don't break it.
PostPosted: Mon Oct 04, 2010 5:06 pm
This is True, make sure you actually have a problem first, but if you do find that it is indeed running too hot those are some ideas. also, if its an old radiator it could be plugged? and if you dont mind me asking, why dont you agree with a 160 thermostat?
Tyler, 19
72 Dart Swinger /6T
Users browsing this forum: Bing [Bot] and 7 guests
