| stalls after freeway https://slantsix.org/forum/viewtopic.php?t=42242 |
Page 2 of 2 |
| Author: | Dart270 [ Tue Oct 26, 2010 7:51 pm ] |
Glad to hear it! You can leave the ballast resistor in there, and that will depend on the coil you are using as to whether it requires a ballast. Just make sure the hot (red) wire for the pertronix goes to a true 12V switched source, and not the downstream end of the ballast. I goofed this once and it kinda ran, but backfired and stalled. Lou |
| Author: | Aggressive Ted [ Wed Oct 27, 2010 12:42 pm ] |
Eppy25, As Lou pointed out you can buy a 3 ohm coil from them. I did and tossed the ballast resistor. They have a couple of different 3 ohm coils. I am using the HEI version. If you would like to see some pictures of the change, click on the red link below my name. |
| Author: | eppy25 [ Wed Oct 27, 2010 5:11 pm ] |
thanks to everyone for the advice. car starts and runs great. the pertronix ignition system and flame thrower 2 coil are in and its such an a amazing difference with that valve job. ~EPPY~ |
| Author: | Dart270 [ Thu Oct 28, 2010 5:12 am ] |
Excellent! Glad to hear it. Lou |
| Page 2 of 2 | All times are UTC-07:00 |
