It is currently Tue Nov 24, 2026 6:19 pm
PostPosted: Wed Jan 12, 2011 4:11 pm
The post 65 8 3/4 center section can be used but I have always installed the "early" thrust spacer into the unit... so I could maintain the correct axle end-play adjustment.
PostPosted: Wed Jan 12, 2011 11:39 pm
Sounds good to me - can early style thrust spacers be bought new? Or has it to be sourced second hand. Presumably this thrust spacer can be directly installed in the new style diff (with no other mods, like side gears and pinions etc)?
Is this the case for both an open diff and a posi?
1960 Plymouth Belvedere 4 door sedan
Stock 60 225
Push button 3 speed Torqueflite
Right Hooker
 Post subject: one more round...
PostPosted: Thu Jun 23, 2011 9:34 pm
I stumbled across this discussion in a site search because I am in the same boat as 60 Pymouth. When I finally got my '60 Dart on the road I was hearing some noise from my diff so I figured I'd start looking for some replacement parts.
After discovering that new ring/pinions sets for the early 8.25 are not to be found, I was somewhat relieved when it sounded like I could just swap in an 8.75 w/741 case for the stock 8.25.
One thing concerns me, though, with this option...when I climbed under the car to get my eyes on the rear end, I counted 11 bolts holding the carrier into the housing. If I'm not mistaken, the 8.75 has only 10 bolts.
An old interchange manual that I have confirms that the '57-'61 axle housing that came with 6 cylinder had 11 bolt 8.25 diff's, while the 8 cylinders had the 10 bolt 8.75 diff's.
So, are we (60 Plymouth and myself) back to square one? If so, any other suggestions?
Thanks for any and all info
Bill
'60 Dodge Dart Pioneer
Vivian
