It is currently Thu Jun 04, 2026 8:50 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Mon Dec 13, 2010 1:42 pm
Since I used the 14 x 4.5 wide rim wheels there were extra steps over drilling the rotors.
1)installing spacers
2)grinding corners of calipers
3)machining hubs
4)making tapered bushings
5)still even longer studs
I'd suggest the 5.5 inch width rims to avoid steps 1 thru 5 however I was into the installation & committed before I discovered this problem & notified Scarebird so they could change their instructions.
I have 18 installation & machining pictures & sketches for anyone using the narrow 14 x 4.5 inch wide wheels.....send me a PM with your email address.
