| aspen https://slantsix.org/forum/viewtopic.php?t=43169 |
Page 2 of 2 |
| Author: | 84aspende [ Tue Jan 11, 2011 6:44 am ] |
| Post subject: | tuebo |
o and thanks turbo66valiant and other u talked m in to doing boost how do i make up a flang for the turbo |
| Author: | Volare4life [ Wed Jan 12, 2011 5:47 pm ] |
young buck not to discourage you, but if your keeping the slant in your F-body your gonna spend some $$$$$ getting it into the 14's NA, I have a '79 Plymouth Volare, your Aspens cuter cousin, you can swap drive train parts between FMJ body cars, lets see if i remember this right '86-89 Diplomats/ 5th avenues, '76-79 Chrysler Cordoba's and LeBaron's obviously '76-80 Plymouth Volare's/ Dodge Aspen's. Performance wise if your going with junkyard parts, my personal option i plan on going turbo, shaker223 did a sick set up for his turbo baby, but to do it on the cheap you need to have welding skills and a welder, heavy guage J tube and straight pipe, some 3/16th to 1/4" strip/plate stock to help support the turbo, and a little imagination and a "doodle pad" to sketch out you ideas before you make a single cut or your first weld i promise you, you will thank yourself later, also make sure you have more than you need on supplies, nothing sucks more than getting 3/4 the way into a project and realizing your not going to have enough to finish it. i will post a sketch later to give you a visual of my concept on how to mount a turbo in a F-body, -Mike |
| Page 2 of 2 | All times are UTC-07:00 |
