V-8 and slant six 904 parts interchangeability
https://slantsix.org/forum/viewtopic.php?t=43174
Page 2 of 2
Author:  bigslant6fan [ Mon Jan 24, 2011 4:39 pm ]
Post subject:  -
It may work OK,but the acumulator softens part throttle shifts,this may not work right ,and you probly have a double wrap rear band in the '83 case,the '68 VB will be "tuned" for a single wrap one.Might not be enough difference to cause problems,but a '68-'73 S/6 case would be ideal.I'm putting '68 V-8 parts in a '71 S/6 case now,I,ll try to post pics soon.
Author:  Reed [ Mon Jan 24, 2011 5:03 pm ]
Wel, even if the 83 case originally had a double wrap band, it will have whatever is currently attached to the 68 valvebody. The only modifications I am making to the internal parts are adding the part-throttle kickdown and swapping the gearset. Otherwise, the V-8 guts will be used in their entirety in the 83 case with the 83 governor and gears.
I am working with what I have, not what would be the most optimal configuration or combination. Please post pics and comments.
Author:  Charrlie_S [ Wed Jan 26, 2011 3:53 am ]
The double wrap band, is a function of the case. You must use a double wrap band in a double wrap case, and a single wrap band in a single wrap case.
I may be wrong, but I'm pretty sure the double wrap band was only the V-8 "999" trans designation, for the 360 engine.
Author:  Reed [ Wed Jan 26, 2011 8:21 am ]
Thanks Charlie. I'll keep an eye out for that. Rear band stays with case.
Page 2 of 2 All times are UTC-08:00
