| Argentine Head is Here https://slantsix.org/forum/viewtopic.php?t=43717 |
Page 2 of 6 |
| Author: | 66aCUDA [ Thu Mar 03, 2011 11:02 am ] |
I emailed the pics to Doug. When he posts them I go thru and narrate them. Frank |
| Author: | 805moparkid [ Thu Mar 03, 2011 1:37 pm ] |
here is a link to FABO for all the pics! http://www.forabodiesonly.com/mopar/sho ... ost1287612 |
| Author: | wvenable [ Thu Mar 03, 2011 5:00 pm ] |
Thanks for the link! What do the ports look like? |
| Author: | 66aCUDA [ Fri Mar 04, 2011 9:25 am ] |
Wayne I wish I could get a picture to do them justice. All I can say is NO obstructions at all. a smooth and LARGE port on both intake and Exhaust. Frank |
| Author: | wvenable [ Fri Mar 04, 2011 9:49 am ] |
Thanks Frank! Man it would be good to get it to a flow bench. Thanks for the pics. |
| Author: | SlantSixDan [ Fri Mar 04, 2011 10:50 am ] |
I'm a little confused about the rocker shaft perches. They look flat on top rather than cylindrically concave. Different rocker shaft setup...? Or am I not looking correctly at the photos? |
| Author: | Dart270 [ Fri Mar 04, 2011 1:10 pm ] |
Yes, flat on top for bolt-on adjustable-height rocker stands. Lou |
| Author: | slantzilla [ Fri Mar 04, 2011 2:27 pm ] |
There's some Jeffrey heads out there that have no rocker stands at all on them. |
| Author: | turboram [ Fri Mar 04, 2011 3:38 pm ] |
Mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm..............OK now I,m in the mood to work on my slant projects |
| Author: | Will [ Fri Mar 04, 2011 5:30 pm ] |
http://i690.photobucket.com/albums/vv26 ... 020548.jpg |
| Author: | 66aCUDA [ Sun Mar 06, 2011 6:30 am ] |
The plan is to flow test the head as soon as I can get to Memphis. Frank |
| Author: | Dart270 [ Sun Mar 06, 2011 6:33 am ] |
Thanks for the pic, Will. Frank, we'll all be interested in flow numbers... Lou |
| Author: | Rick Covalt [ Sun Mar 06, 2011 12:46 pm ] |
| Post subject: | numbers! |
Are you there yet? What's the hold up!! Quote: The plan is to flow test the head as soon as I can get to Memphis.
| Author: | ChYmAiL [ Sun Mar 06, 2011 4:19 pm ] |
I was on holiday! Im glad the head arrived perfectly Frank! Hope you can push a lot of horsepower with this! Thank you so much for your trust. |
| Author: | DadTruck [ Mon Mar 07, 2011 4:29 am ] |
Frank the "added material' around the combustion chambers in the close up views appears in the photos to have a different gloss than the remaining firedeck area. Is that the same appearance in person? If so, are the closed in combustion chambers welded material? certainly a nice find,, and the dragster is just as cool! |
| Page 2 of 6 | All times are UTC-07:00 |
