It is currently Mon Sep 21, 2026 11:45 pm
PostPosted: Sun Mar 27, 2011 3:24 pm
The annual rebate ($40-50) on Walker quiet-flow mufflers is due............
(and don't forget the 5% off rockauto discount)
Might have already started, usually it's april-may......
Look at a walker 21206.
PostPosted: Sat Aug 27, 2011 1:11 pm
So I'm seeing a lot Walker part #s being thrown around here, and parts store search turns up even more part #s. What are these all dependent on? Just the dimensions of space you have to work with? Or are there other factors? Did you commit to one yet? I have a '68 Dart I'm shopping for. Thanks for your input.
J.R.
Tucson, AZ
'68 Dart 270 with a '76-'80 engine
PostPosted: Sat Aug 27, 2011 3:15 pm
The physical properties:
1) Muffler length/diameter/space available
2) Inlet pipe diameter
3) Pipe inlet placement, offset or center
4) Outlet pipe diameter
5) Pipe inlet placement, offset or center, also relative to inlet if offset on both sides
6) Special hanging brackets placement, if required
7) Size of wallet
8 ) Noise sensitivity 8)
Olaf.
Aspenized
PostPosted: Sat Oct 15, 2011 8:10 am
Haven't been around for a bit and just saw this.
I ended up using the Walker 21200.
Here's a Link to my install
Super Six Conversion Stromberg
Users browsing this forum: DuckDuckGo [Bot] and 14 guests
