It is currently Fri May 22, 2026 3:32 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
 Post subject: Axle Removal
PostPosted: Tue Nov 12, 2002 9:37 pm
All you need to do is jack-up the car and make sure it is well supported on stands, remove the wheel and look for 4 nuts under the axle flange. There will be a quarter size hole in the axle flange you can use to put a socket through to remover the 4 nuts.
Once all the nuts are off, pull on the axle to see if it pops-out easy, most will not. (stuck) If it's stuck, install the brake drum up-side-down and screw on 3 nuts up-side-down, 3-4 turns. Now slide the drum all the way back on the studs the quickly outward to "bang" into the nuts, that will usually pop the axle out.
