Do I really need a whole new rear end?
https://slantsix.org/forum/viewtopic.php?t=4422
Page 2 of 2
Author:  Doctor Dodge [ Tue Nov 12, 2002 9:37 pm ]
Post subject:  Axle Removal
All you need to do is jack-up the car and make sure it is well supported on stands, remove the wheel and look for 4 nuts under the axle flange. There will be a quarter size hole in the axle flange you can use to put a socket through to remover the 4 nuts.
Once all the nuts are off, pull on the axle to see if it pops-out easy, most will not. (stuck) If it's stuck, install the brake drum up-side-down and screw on 3 nuts up-side-down, 3-4 turns. Now slide the drum all the way back on the studs the quickly outward to "bang" into the nuts, that will usually pop the axle out.
Page 2 of 2 All times are UTC-07:00
