| 1980 Chrysler Racer Found!! Airport Tug https://slantsix.org/forum/viewtopic.php?t=44316 |
Page 2 of 2 |
| Author: | Dart270 [ Sat Apr 02, 2011 4:22 pm ] |
You can just flatten the grass, no need to mow. Lou |
| Author: | Rob Simmons [ Sun Apr 03, 2011 7:26 am ] |
This is really cool!! I understand the scrap price draw to dismantle it, but you have to be at least a little bit tempted to keep it like it is... Then again, I may be just a little bit more "Slanted" than most... |
| Author: | Rick Covalt [ Sun Apr 03, 2011 12:23 pm ] |
| Post subject: | let me be clear |
This thing is a tank. I don't need a tank! I don't want to race Lou in a tank while he pulls away on his bicycle. Rick |
| Author: | GTS225 [ Sun Apr 03, 2011 12:37 pm ] |
Dibs on the "parachute lever"! (BTW....does that one have the knob that turns to adjust cable tension?) Hmmmm....something else, too....maybe. When you get to a point that you can look it over fairly well, I might be interested in the trans-mounted park brake assembly. Hopefully, it will mount onto a 904 without too much effort. Roger |
| Author: | Rob Simmons [ Sun Apr 03, 2011 6:57 pm ] |
| Post subject: | Re: let me be clear |
Quote: If you want an autographed picture of me beside the Tug, it will be $10 and all proceeds will go to the Mason Dixon race!!
Um,... Thanks, but I think I'll pass. I've got plenty of t-shirts, hats, license plates and stickers in support of the Mason Dixon race. Rick |
| Author: | ceej [ Sun Apr 03, 2011 9:02 pm ] |
Quote: Y'all have green cows in Maine?
Is it moss like the cows here in Oregon?Lou CJ |
| Author: | Big T [ Mon Apr 04, 2011 8:21 am ] |
| Post subject: | Moss |
Ceej - |
| Author: | Rick Covalt [ Tue Apr 05, 2011 9:54 am ] |
| Post subject: | Shifter |
The shifter in the tug looks like some I have seen in some 60"s trucks or something, can't remember. But it had a very simple cable set up. here it is. ![]() Large bolt held the bracket to the large factory tab on the side of the tranny. Clevis went to the shift lever. The yellow bracket was an arm to hold the kick down lever back in the correct position. Would this likely work on a 904?? I plan to hold on to the shifter for now. |
| Author: | wjajr [ Tue Apr 05, 2011 12:46 pm ] |
Quote: Dart270 wrote:
Augh, ain’t there any artsy-fartsy types here? ThinkAndy Warhol… LOL.Y'all have green cows in Maine? Lou Is it moss like the cows here in Oregon? CJ Now the last time I motored past this bend in the road, the cows were neither green or moss covered, but brown and the air stinking blue… |
| Author: | Reed [ Tue Apr 05, 2011 12:53 pm ] |
The shifter looks strongly like an A100 shifter. |
| Author: | slantzilla [ Tue Apr 05, 2011 2:32 pm ] |
Quote: The shifter looks strongly like an A100 shifter.
D series used the same thing in the early '60's.
| Author: | GTS225 [ Tue Apr 05, 2011 4:47 pm ] |
Rick.....you misunderstood my request. I'm interested in the park brake lever, and possibly the trans(or diff)-mounted park brake assembly. Not the shifter. I have a '23 T-bucket project stashed, and Iowa law requires a non-hydraulic parking brake for inspection and licensing. If I'm not mistaken, those tugs have a trans or diff mounted, drum setup that might be adaptable. Roger |
| Author: | Rick Covalt [ Tue Apr 05, 2011 5:08 pm ] |
Got your PM Roger. I understood your request, I just wanted to get it out on the floor and see what I have. I just posted about the shifter cable set up as a FYI Rick |
| Author: | Rick Covalt [ Fri Apr 08, 2011 6:10 pm ] |
| Post subject: | Headed out |
Mr Tug racer is headed for that great scrap yard in the sky first thing in the morning. Fairwell old friend |
| Page 2 of 2 | All times are UTC-07:00 |
