| Fuel rail construction? https://slantsix.org/forum/viewtopic.php?t=44374 |
Page 2 of 2 |
| Author: | Will [ Sat Apr 30, 2011 5:03 pm ] |
Welded in bungs, Fuel rail drilled to o'ring size 2 stand offs taped with a socket head cap screw to hold it on.Will http://i690.photobucket.com/albums/vv26 ... 040398.jpg http://i690.photobucket.com/albums/vv26 ... 040399.jpg http://i690.photobucket.com/albums/vv26 ... 020544.jpg |
| Author: | slackdog [ Sat Apr 30, 2011 5:51 pm ] |
| Post subject: | Injector bungs |
Got a it of an angle on them,Did not get too excited its not a sequential setup its batch fire.i am running all holden commodore setup with the holden 808 ecu.ok at the moment Fired it up the other day and after sorting an excessive oil pressure problem it runs ok at the moment.still some things to sort out Rob |
| Author: | MenkeMoose [ Thu May 05, 2011 3:48 pm ] |
Here's another option for the fuel rail. It's more expensive than the Ross rail but I like that it already has the 6AN fittings on it that I wanted. They will also drill the bungs for you for another $50. Moose |
| Author: | Reed [ Thu May 05, 2011 3:54 pm ] |
Thanks Moose! That isn't a bad deal at all. |
| Page 2 of 2 | All times are UTC-07:00 |
