| SuperSix conversion issue... https://slantsix.org/forum/viewtopic.php?t=44449 |
Page 2 of 2 |
| Author: | Doc [ Tue Apr 12, 2011 1:10 pm ] |
Tie the KD lever back about 1/2 way (rearward) and keep your foot out of it for the short drive to storage. DD |
| Author: | Reed [ Tue Apr 12, 2011 1:34 pm ] |
Or, go grab that bar off of any slant or v-8 powered 904 in the boneyard. You should have gotten a little cube shaped clamp on the end of your Super Six kickdown. This cube clamps tot the kickdown rod and has a peg and that passes through the hole on the transmission kickdown arm. There is a cotter pin that passes through the peg n the cube to hold it on the transmission arm. Get the right pieces in the long term, but in the short term do what Doc says. |
| Author: | Jester [ Tue Apr 12, 2011 1:40 pm ] |
ah, I'm missing the cube. I'll head to the boneyard and try to find the cube lol... any 904 equipped v8 or v6? shouldn't be too hard to find |
| Author: | Reed [ Tue Apr 12, 2011 2:17 pm ] |
Yup. The cubes were standard starting in the mid to late 60s. I believe the hole in the transmission arm is a different diameter between the clip on style like you have and the cube. I would get the cube and the arm. You will need to pop off the shifter lever from the tranny and then pop off the kickdown lever. Try and find a truck, van, or ramcharger simply for better clearance around the tranny.
| Author: | Jester [ Tue Apr 12, 2011 5:22 pm ] |
The only one I found was from a '79 Diplomat (tranny already removed. Easy pickings), and it fits nicely, but doesn't push the lever all the way back at full throttle. There's probably a 1/32" movement before it hits the rear stop. Drives and shifts fine as far as I can tell... Can't wait for the electric choke to get here in a few days. Once it's warmed up, the supersix with new Holley 2280 is great so far; no hesitation, instant power and seemed to be tuned pretty close as a bolt on. (it's a 318 spec 2280, so I still have to modify the choke connection) Big thanks to Reed and the rest |
| Page 2 of 2 | All times are UTC-07:00 |
