It is currently Sun Nov 22, 2026 10:35 pm
PostPosted: Tue May 03, 2011 3:21 pm
One thing I did not expect with the 3 on the tree was that the shifter would rest on my leg in 1st and 3rd gears.
Sounds like your column shifter is way off. Neutral should be with the shift lever horizontal. First is pull the lever to your self (from neutral) and down about 6-8 inches. Or less. If neutral is in the right place and first/third is in your lap you have to much slop in the linkage some place.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Tue May 03, 2011 6:03 pm
Thanks 4 speed. N is actually a couple degrees north of level. It sags about 3/4 of an inch. I wasn't exaggerating about my inseam, 40" with boots on, 38" barefooted. I've had one car in hmm 20 now that I actually fit in. A blazer with a tilt column and a 13" steering wheel. I once had an 84 ranger truck. I couldn't figure out why my knees ached so bad. Then I realized I had to work the pedals bowlegged around the wheel. Haha! Nah, swapping the wheel and contemplating moving the seat slide rail is all part of me owning a car
I'm pleased with myself for giving a damn.
PostPosted: Wed May 04, 2011 8:25 am
The seats have a fixed way of mounting them farther back and then you use the track for "normal" adjustment. And I think you can tilt them more to.
