| Passenger wheel trouble! https://slantsix.org/forum/viewtopic.php?t=45076 |
Page 2 of 2 |
| Author: | Slanted Opinion [ Mon Jun 13, 2011 2:39 am ] |
In your original post you mentioned checking the ball joints by trying to wiggle the tire while the car is on a lift. That procedure will NOT reveal a bad ball joint. Raise the tire off the ground slightly by jacking underneath the lower control arm, close to the drum. Now place a flat bar between the tire and the floor. Use the bar to move the tire up and down. Any play there (Chrysler says over .070 of travel) means you have a bad ball joint. - Mac |
| Author: | Nongan [ Mon Jun 13, 2011 8:55 am ] |
I probably should have mentioned that I did load the Lca when I tested ball joints. Sorry guys |
| Author: | Slanted Opinion [ Mon Jun 13, 2011 1:12 pm ] |
Excellent! No criticism meant... just wanted to be sure you were checking them properly. They're pretty important things! - Mac |
| Author: | Nongan [ Mon Jun 13, 2011 7:25 pm ] |
She's back together! And handles 40 times better than before! I know this isn't the engine section but i was driving it after putting it all back together and it died a couple times when i stopped, I got tired of it so I pulled over and pulled off the air cleaner and a bunch of vapor went everywhere, can someone explain this to me, I've never had it happen before. Thanks, Seth |
| Page 2 of 2 | All times are UTC-08:00 |
