It is currently Mon Nov 23, 2026 9:39 pm
PostPosted: Fri May 27, 2011 8:11 pm
Tracks don't like to clean up gear lube from the starting line so they ban welded gears. If they know you have one, they won't let you run. If they think you have one and you say you don't they will make you take the cover off for them. Making the track happy is easier on you.
Later
Ryan
Yep, that is the reason a welded diff won't pass tech if they know you have one. If tech happens to have any gravel or dirt near it they will see the tires scooting. Even with a spool you still have to have aftermarket axles, and none are available for the 7-1/4 anyway.
It's OK to not have much money and want to race, but that is no excuse to become stupid about things. :shock:
 Post subject: Didn't know that?
PostPosted: Sat May 28, 2011 5:03 pm
I guess I won't buy a spool for my 3.91 then. I just had big bolt axles cut down for my rear, and I thought it may be cheaper to get a spool for the rear when I am running at the strip. If I put it on the road I have a good set of road gears. 2.94's
Thanks,
Rick
PostPosted: Sat May 28, 2011 9:09 pm
I'm not gonna beat up on ya it's just a question about some welded gears not a touchy topic like the meaning of life lol but if it's not gonna be a drift car i don't think welding em would be wise besides your slant should have no traction problems it's still a stocker isn't it unless you got some major plans for the motor i wouldn't worry about this stuff for a while or when traction becomes a problem.
Kev
