| running poorly after a solid week! https://slantsix.org/forum/viewtopic.php?t=45091 |
Page 2 of 2 |
| Author: | easy803 [ Tue Jun 21, 2011 1:17 pm ] |
so i got to fiddling with the coil and it seems i have a bad ground, i deff do now as the black wire attached the the node on the block came right off... also my coil had a bunch of gunk on it im assuming oil from the inside... car still starts up and runs the same as it did.. my meter doesn't do Omhs... should i replace the coil for good measure? |
| Page 2 of 2 | All times are UTC-07:00 |
