It is currently Tue Dec 30, 2025 8:56 pm
Post new topic  Reply to topic  [ 42 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Wed Jul 27, 2011 3:26 pm
I've run a glasspack on a factory manifold to a 2 1/4" single exhaust. I thought it sounded OK. It was a decent sound with the expected drone at highway speeds. I now run Clifford shorties to a true dual throug an x-pipe with Smithy's 22" (I think) mufflers. My current system is 2".
I think my current setup is actually a bit quieter when driving normally, but when I get on it, it screams. It is the best-sounding six cylinder I've ever heard in person (although it still has that drone I was trying to get rid of. If it really bothers me I'll spring for some Flowmaster 50 series)
PostPosted: Wed Jul 27, 2011 9:17 pm
Here's a little diddy of mine in action,loud? some would say yes I say no.
Clifford shortys,twice pipes to the rear with some no name 12" glass packs up by the trans.
http://s339.photobucket.com/albums/n450 ... r048-1.mp4
PostPosted: Thu Jul 28, 2011 11:43 pm
6shot I like how your car sounds on the top end. With my straight exhaust it has a deep throaty growl all the way up and then really starts to roar past 3k. People roll there windows up when I drive by. Especially when I get on it. It is very quiet at idle though.
Cody
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
 Post subject: .
PostPosted: Fri Jul 29, 2011 8:54 am
I like walker super turbos.
PostPosted: Fri Jul 29, 2011 9:17 am
I'll post a video of mine later, but I ran my own 2.25" from the manifold to the driver quarter, coming out right before the rear tire. I think it sounds nice, whih is all that matters. I got rid of that funky headpipe with the 3 bends in it and did one continuous sweep from the flange to the tranny crossmember, then I put in a 24" thrush glass pack in as close as I could to the tranny crossmember, and then swept it out the side. It has a nice quiet idle, a real nice rumble during regular driving, roars in the midrange and screams at the top end
Annabelle: 1970 Dodge Dart Hardtop
1991 Nissan 240sx (sileighty) Lots of mods
1974 Dodge Dart *Wrecked*
PostPosted: Sat Jul 30, 2011 7:40 am
this looks very simple but has anyone tryed this style?
http://www.shop.speedunlimited.com/p-63 ... ffler.aspx
slant six's RULE!
http://www.usajon.com
PostPosted: Sat Jul 30, 2011 9:51 am
That might get you legal, but it's not good for power. Take the car to the track where you can run open exhaust. Find the right length header extension, build a pressure wave termination box and then extend the exhaust to the muffler.
PostPosted: Sat Jul 30, 2011 12:32 pm
First post here. I have a '65 A100 pickup that has a newer Super Six in it. I pulled it out of a junkyard (sat for several decades) last month and did enough mechanical work as necessary to get it road worthy (short trips that is). It didnt have any muffler on it at all so I threw on a Smithy's "glasspack" muffler that I had laying around. If I recall it is 2 1/4" in/out and about 2' long. It is pretty quiet at idle and only burbles a little bit at throttle. I have ridden in rigs with inline engines and glasspacks before and noticed a distinct, and annoying, drone they can produce. So far I have not heard any of this from mine. It really is quite quiet. Too much so..........
PostPosted: Sat Jul 30, 2011 1:01 pm
here's a short youtube..
please note my high preforamnce grunt getting out of the Dart @ the end..
Ha!
http://www.youtube.com/watch?v=YHOJ-zJURNU
slant six's RULE!
PostPosted: Sat Jul 30, 2011 1:22 pm
hey thanks
i just read up and it states that a pressure wave termination box is large, that after the collectors it creates a vacuun by being a large exhaust dump area, thus drawing the next exhaust gases into it..some builds suggest gutting a muffler..
old article
http://www.popularhotrodding.com/engine ... ndex1.html
slant six's RULE!
PostPosted: Sat Jul 30, 2011 9:33 pm
As I promised, here is a video, the squeaks are from the grant steering wheel, I need to pull it off and lubricate the ring for the horn. I get on it for a little around :30 and then again at 1:30. http://www.youtube.com/watch?v=THvge7qkYiI
PostPosted: Sat Jul 30, 2011 10:20 pm
...t a pressure wave termination box is large, that after the collectors it creates a vacuun by being a large exhaust dump area, thus drawing the next exhaust gases into it..some builds suggest gutting a muffler..
Actually, the box just makes the exhaust system appear to the pressure waves to end at that point just as it would with an open pipe. It ends the acoustic tuning at that point so that the rest of the exhaust system doesn't affect the tuned length.
PostPosted: Sun Jul 31, 2011 6:43 am
copied from www.LS1tech.com
David Vizard goes into quite a bit of detail on "termination boxes" in his book "how to build a small block Chevy on a budget" or something like that.
The terminator box is basically a hollowed out muffler. A RACING Flowmaster single chamber muffler (I know everyone hates Flowmaster, but it is just an example with a big empty area inside it) placed after the header collectors will effectively tune the length of the collector. Longer collectors (18-24") tune for more mid-range torque while shorter collectors tune for high-rpm torque (5000+).
The terminator box gives the exhaust pulses somewhere to expand, which then causes a slight vacuum. The slight vacuum draws more exhaust out of the cylinders during the exhaust stroke and more importantly -- with a cam with lots of overlap -- draws more fuel/air in during the intake stroke.
slant six's RULE!
PostPosted: Sun Jul 31, 2011 5:21 pm
got one on my d150 and also on wife's 05 scion xb....both have a bit of grumble ,not to loud...acuataly gained a bit of milage in scion
PostPosted: Tue Aug 02, 2011 2:07 pm
well exhaust is an issue
bought some flowtech 2.5 header collector flanges that drop down to a 2.25, installed say two 4 ft. of 2.25 alumunized tubing..real loud but better then just headers..just ordered old sckool thrush glasspacks 2.25 x 31
we see how these sounds....
http://www.jegs.com/i/Dynomax/289/24205/10002/-1
slant six's RULE!
Users browsing this forum: Google [Bot] and 6 guests
