It is currently Sun Nov 15, 2026 10:32 pm
PostPosted: Fri Sep 02, 2011 10:21 am
Well I did a sanity check and I agree that 3/4" (19.5mm) od tube is overkill.
I think a 5/8"(15.75mm) od .527" (13.38mm) id tube is a little more approprite that way I can use the same stock for the body and the injector glands, with some boring.
What is the actual od of the injector to rail o ring? I want to get at least .010" (.25mm) "crush" on the o ring to get a good seal.
What would be the the easiest/best fittings to use on the ends of the rail for fuel in and out?
Also how should the rail be held down?
I'm thinking of spoting on some sheet metal strips that could be bent at a 90 for a bolt to hold it down to the manifold.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sat Sep 03, 2011 4:38 pm
I have a rough drawing I did in MS paint of a the rail I have in mind here.
I can make something like the rail on the link for about $200 USD.
If you want something else made pm me and I will see if I can build it.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sun Sep 04, 2011 10:36 pm
I would also be interested in a set of fuel rails. I'll be watching this thread to see how they turn out.
It's a Slant thing. Even I don't understand.
1974 Duster, EFI /6 soon to be turbo...
Get that Monkay! Get that nasty thing!!
 Post subject: Fuel Rail
PostPosted: Sun Oct 16, 2011 7:08 pm
Hey carlherrnstein I have a lot of factory fuel rails but of-coarse I have never found one that will work for our application on the slant six. If you need o-rings or a few injectors to test with or I could ship you a rail or two that might help with your design, let me know.
I can be reached threw my website http://www.doctorinjector.net/
were I provide fuel injector flow testing and cleaning, injector parts And injectors.
Fast is fine but accuracy is final. You have to learn to take your time ... in a hurry
- Wyatt Earp
