| Have I found TDC ? https://slantsix.org/forum/viewtopic.php?t=46781 |
Page 2 of 2 |
| Author: | Reed [ Thu Oct 27, 2011 1:54 am ] |
Thank you Charlie, I stand corrected. I thought the timing dots lined up at #1TDC on the compression stroke. If the dots line up at TDC on the exhaust stroke, then Slanty 6 is doing everything right. My sincerest apologies for giving incorrect information. |
| Author: | Charrlie_S [ Thu Oct 27, 2011 5:57 am ] |
No problem. It would seem logical to have the sprockets line up dot to dot, at #1 TDC compression, but that is not the case. The first time I tried to degree a slant cam, I was confused, and thought the sprockets were mismarked, but that is just how it is done. |
| Author: | Rob Simmons [ Thu Oct 27, 2011 7:12 am ] |
I just learned something new too! I always thought the same thing Reed did. Thanks Charlie! |
| Author: | slanty6 [ Thu Oct 27, 2011 11:10 pm ] |
| Author: | SlantSixDan [ Thu Oct 27, 2011 11:42 pm ] |
I found TDC—it was behind the sofa all along!
| Author: | sandy in BC [ Fri Oct 28, 2011 8:07 pm ] |
Quote: I found TDC—it was behind the sofa all along!
Please!...we live in Western Canada now.....say Chesterfield!
| Author: | wjajr [ Sat Oct 29, 2011 7:25 am ] |
Sandy: Quote: Please!...we live in Western Canada now.....say Chesterfield!
Remember Dan is Canadian on paper, not natural born, hence most likely the lingo slip.In Maine we say; just because the cat has kittens in the oven don’t make them muffins. I offer an international lingo compromise: Davenport. A little burning question of one that parks endlessly on a Davenport: would he be called a Chesterfield Potato? That kind’ah grates on one ear, there ah? LOL |
| Author: | SlantSixDan [ Sat Oct 29, 2011 10:03 am ] |
I found TDC—it was behind the Marlboro all along!
| Author: | Dart270 [ Sat Oct 29, 2011 3:12 pm ] |
Line up the dots, and see if you can make to the bed before you stumble and fall... Make sure you have a plastic trash can nearby. Cams are for sissy's anyway, I use F1 spec pneumatic valve actuation with computer control!! Lou |
| Author: | sandy in BC [ Sat Oct 29, 2011 4:41 pm ] |
Quote: A little burning question of one that parks endlessly on a Davenport: would he be called a Chesterfield Potato?
............we call them.....teenagers.
| Author: | slanty6 [ Wed Nov 02, 2011 12:20 am ] |
Allright boys, swinging this a bit more on track now I got a few more questions. 1) Shouldn't there be an oil slinger disk somewhere between the crank snout and sprocket/ timing chain cover ? I could be thinking of one of the industrial engines at work so please excuse me.. 2) Do I need to drop oil pan slightly to get the "wedges" of the timing chain cover bottom gasket in ? Or just the bolts that I removed to get the cover out ? 3) Use regular pipe "dope" on one timing chain cover mounting bolt that threads into a coolant passage way ? |
| Author: | Reed [ Wed Nov 02, 2011 9:31 am ] |
Quote: 1) Shouldn't there be an oil slinger disk somewhere between the crank snout and sprocket/ timing chain cover ? I could be thinking of one of the industrial engines at work so please excuse me..
Possibly. Some got them, some didn't.Quote: 2) Do I need to drop oil pan slightly to get the "wedges" of the timing chain cover bottom gasket in ? Or just the bolts that I removed to get the cover out ?
Yes and no. You are supposed to drop the pan a bit to get wedges seated. However, I leave the pan in place, put a bit of RTV sealant in each corner, and force the timing chain cover in place. It works for me.Quote: 3) Use regular pipe "dope" on one timing chain cover mounting bolt that threads into a coolant passage way ?
Not necessary. If you want, run a tap through the threads and run the bolts through a die to clean up the threads, but no sealant or putty is necessary.
| Page 2 of 2 | All times are UTC-07:00 |
