| Aluminum Heat Diverter https://slantsix.org/forum/viewtopic.php?t=46953 |
Page 2 of 2 |
| Author: | wjajr [ Sun Nov 13, 2011 7:03 pm ] |
Danarchy: Quote: The car also had a grill cover that worked like a horizontal roman shade from a pull handle under the dash
Most of the high end cars of the 20’s & 30’s had louvers thermostatically controlled to adjust air flow to radiator, rather than an in head thermostat used on more modern cars.
| Author: | Sam Powell [ Mon Nov 14, 2011 7:40 pm ] |
Quote: NE. uses aluminum license plates with no embossing. Would one of those work good for this?
Sure. Perfect.Sam |
| Author: | 2 Darts [ Mon Nov 14, 2011 11:23 pm ] |
The only reason I can see for rounding the corners is to reduce the potential for injury. From experience, I can also suggest putting a file to edges created by tin snips. The little buggers can be hard on hands. |
| Page 2 of 2 | All times are UTC-08:00 |
