It is currently Sat Nov 28, 2026 4:33 am
Post new topic  Reply to topic  [ 69 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Fri Dec 09, 2011 6:35 pm
I saw your post,, and it looks like a build close to what I am doing,,I am using a manual tranny while you are going with an auto,,. But I am hesitant to offer any 'expert' advice as this is my first build. There are a lot of real knowledgeable folks on this forum, but cams seem to be a personal choice, and maybe rightly so.
Each vehicle and driver has its own personality,, and the cam play's a big part in setting the engine's personality.
I have documented most of the decisions that I have made concerning cam choice. Will my motor work out as planned? Won't know till it gets built.
Good luck with yours, Keep asking- researching and posting on what you do.
I am also using a 2280,,, are you targeting premium or regular gas?
regards
DT
PostPosted: Wed Dec 14, 2011 12:26 pm
Car Model: 1962 Dodge Lancer GT Black/Red
Thank you all for the replies so far.
I have edited my original post in that I have verified that the transmission is actually a 904. I rashly assumed that trucks did no use 904's. Thank you for that Reed and RaMop.
Just wondering, Reed, did you ever finish brothers '83 van? What did you use there and how did that work out?
Thank you Ceej for your suggestion. I just want to say that I am shooting for a Highway vehicle, rather than a stump puller, that will carry at most 1500 lbs in addition to driver and vehicle. 500 lbs of that 1500 is the lift gate. It will rarely ever carry more than 500 lbs of freight. Currently it weighs about 4200 lbs with the driver and lift gate.
I must say, in addition, that I really appreciate the thread and the research that DadTruck has added to this topic. Your latest graph representing the 1333 intake and 1527 exhaust design appears rather impressive. Do you see any reason that wouldn't be the best choice for my build?
 Post subject: Regular or Premium
PostPosted: Wed Dec 14, 2011 12:37 pm
Dad Truck,
I was shooting for about 9.2 compression, but am now thinking of staying between 8.5 to 9:1 as the builder is suggesting a lower ratio for heavier work. I won't know for sure till he cc's the head and the calculations are made.
Ted at PER suggests running premium but at this ratio and use I personally don't see the need for it. I was also just reading online (the supreme source of all truth in this day and age) more btu's are available with lower octanes for low end torque. Not sure I understand that one.
PostPosted: Wed Dec 14, 2011 1:01 pm
Less BTU's in ethanol. Ethanol has more octane. You need to jet up from conventional gas to run the same octane ethanol blend.
You are running leaner. Ping-ping-ping!
PostPosted: Fri Dec 30, 2011 8:10 am
I bought a high performance hydro head off EBay some years back from a guy that had followed one of the enthsusiast magazine slant six builds. It had about 1000 miles on it.
It was shaved .100", had the 1.70" and 1.44" Egge stainless valves and was pocket ported to improve the breathing. It was originally slated for another application but is perfectly suited for this job.
Wanting to be sure that it was everything that it was claimed to be I took it to be checked out at PER. Boy am I glad I made that choice. While all the claims made were true, the work left a bit to be desired.
The larger valves were not properly seated in the head but poked into the combustion chamber, I think he said, about 1/8th inch. The hardened part of the seats had been ground away. He also didn't care for the angling and contact area between the valve and seat. There were no valve guides installed and Ted found that the air flow chamber had been opened up some, it was not optimised for good flow. Other that that, the head was structurally sound.
Ted will be installing hardened seat inserts,valve guides and clean up the bowls. Then we will be able to get a proper volume reading on the chambers.
At least I should save some money on parts. Next he will open the 'rebuilt' short block I bought from a farmer in CA.
 Post subject: Torque or HP?
PostPosted: Fri Dec 30, 2011 8:56 am
You have to watch what is considered "good flow"...when porting, especially on a slant head. There's a real line between cleaning up
the ports and retaining narrow passages for best low end torque
(=high port velocity at lower flows or smaller carbs). Recently I got to compare two heads that I had the 1.70/1.44 valves installed in and
had the seats replaced as well. In each case I cleaned up the ports
but did not open the ports up, one head had bowl blending done
to it without much else, the other head the machinist saw there was
going to be some issues with the new seats and used his cutter to
open up the bowl area to match...The later head that the cutter was
used, lost a fair amount of low end response and was sluggish up to
2500 rpm, at which time the demand on the engine and the ram tuning of the hyperpak made use of the flow and everything was great, but on the
street I don't have any use for anything above 2300 rpm...
On the flip side I just turn another head over to my local machine shop after I did a rough port and I opened the whole thing up all the way through, I expect this will work just fine at Woodburn at 4-6000 rpm.
Just food for thought.
 Post subject: Thx DI
PostPosted: Fri Dec 30, 2011 9:21 am
Thx DI. That smells like Fillet Mignon. I will look into that. I think the bowls is what we are talikng about. He doesn't see much value in port blending for a low rpm torque motor. Again thank you for the value of your experince. -Ray :)
PostPosted: Fri Dec 30, 2011 9:53 am
Opening up the intake ports about 1/8" bigger than the gasket will create an anti-reversion effect. I used that technique when building a head for a van. Should work well on any street motor.
If you open the exhaust manifold up the same way it creates the same effect on the exit side.
Exhaust manifolds are harder to port than heads. A bunch faster to take them to a machine shop.
 Post subject: Progress report
PostPosted: Wed Jan 11, 2012 9:56 am
Picked up the Hooker header and Offy intake from the Brooks Ceramic Coating on Monday. Looking good. Cam was delivered Tuesday. Thank you Dadtruck for the before of your research.
The head work is done; chamber volume measured at 40 cc. Sounds tight I'll have to see how that specs out.
It is exciting to see it coming together.
PostPosted: Wed Jan 11, 2012 2:07 pm
I skinned .60 off a '74 model head. It finished out with stock valves and no polishing at 45cc's.
PostPosted: Wed Jan 11, 2012 3:17 pm
Did you notice the improvements you were after on that, Rug?
PostPosted: Wed Jan 11, 2012 4:05 pm
wow ..... am in the midst of getting a build together myself....85 w150,just picked her up...going to use 85 lower, change over to mech purple mopar cam 278 dur,roller chain,dultra duel duels,offy 4bl manifold, head shaved .90, oversize valves,340 springs.... waiting on head , it been visiting @ shop...takes a while with this guy,but he ol' school rodder,does great work... going to run 2&1/2 thru blown out cats,shortys and stacks with clappers.....got granny low and 31 inch tires...need to check if rear limited-slip
keep o roddin'
Indian
PostPosted: Wed Jan 11, 2012 5:01 pm
It's still sitting in the shop 2 years later. My Duster had .090 off it. Gasket matched and bowls done and polished chambers. Lots of umphh! Stock valves. It ran 10.59's @ 59mph in the eighth with open 3:23's and stock cam and 198cid. Did CC the head.
I built a "peanut" head for a friends '80 van with ported 1/8th in. bigger than the gasket on the intakes. Bowls worked, stock valves, polished chambers. Unshrouded the valves. .060 off it. I smoothed the exhaust side, can't remember how much I opened it up. This van would pull the hills in with the OD833 in high gear loaded with his tools. He was stocked at the power.
One thing I do is smooth a trench coming off the spark plug hole toward the exhaust valve. I think I read that was a good thing to do.
I like "whittling" on heads.
On any of these heads cut the cast flash on where the oil drains back to the lifters. Grind some wide grooves.
PostPosted: Wed Jan 11, 2012 5:47 pm
MotoGrey
how is your build progressing? Where did the head cc -piston recession and compression end up?
Got my cam back from Oregon, I have been playing phone tag with the shop doing my machine work,,I'm going to run down there on Monday..
regards
DT
PostPosted: Wed Jan 11, 2012 5:49 pm
So I take it, you don't see a great advantage to larger valves on a daily driven slant?
Users browsing this forum: DuckDuckGo [Bot] and 5 guests
