Rear cam bearing
https://slantsix.org/forum/viewtopic.php?t=47825
Page 2 of 2
Author:  1964valiant [ Mon Feb 06, 2012 2:26 pm ]
That was a close call :shock: . Thats alright Reed. Thank you Charrlie. i should of checked the order of the bearings twice :oops:
so hydraulic bearings would not work because it is originally a solid lifter block?
Is there a down side if the cam does not have a groove?
Author:  Reed [ Mon Feb 06, 2012 2:50 pm ]
Buy the bearings to match the block.
If the cam does not have a groove, then it isn't a factory hydraulic slant six cam. I don't know if aftermarket supplies use cam blanks with grooves to make the hydraulic cams. For instructions on how to change a mechanical cam motor to a hydraulic cam, see HERE.
Author:  slantzilla [ Mon Feb 06, 2012 6:21 pm ]
As far as I know there was never a grooved rear cam bearing. The groove was on the cam.
It is the front bearing that has the groove.
When I built my first good motor it was generally accepted Internet lore that the factory bearings had a groove in the rear bearing. I could never find grooved bearings.
I believe that can now be laid to rest.
The MP cam I got from Mike last weekend is grooved.
I had a Lunati hydraulic. I can't remeber if it was grooved or not.
Getting old is not for the timid. :shock:
Author:  kielbasa [ Mon Feb 06, 2012 6:54 pm ]
i just tore apart which i believe is a competley untuched motor. it has std/std factory bearings, factory stock pistons, still had rope seal, blah blah
and none of the cam bearings had a grove, and the rear one had 2 holes.
Author:  DusterIdiot [ Mon Feb 06, 2012 7:00 pm ]
Post subject:  Yes...
I know the blanks OCG has are that way, and since they are low on original mech blanks with good fuel pump lobes, they will make a deal
on a new hydraulic blank if you order a mech camshaft, but ask for the
groove...(I did this on my last order since I am never sure if the new blanks are drilled correctly or not for the oil feed...)
Author:  Charrlie_S [ Tue Feb 07, 2012 2:33 am ]
I put a small groove on all my cams. If I wind up with excessive oil to the top end, I can always install a restrictor in the oil passage in the rear rocker stand, without taking everything apart.
Page 2 of 2 All times are UTC-07:00
