Offy vs. Weiand 4bbl
https://slantsix.org/forum/viewtopic.php?t=47846
Page 2 of 2
Author:  Aggressive Ted [ Fri Feb 10, 2012 11:21 am ]
Post subject:  Dyno run
Rug_Trucker,
Do you want to see dyno results with a 2 barrel BBD on a Weiand or 4 barrel on a Weiand.
Once my "Torque and Mileage Build" upgrades are done and engine broken in, this spring I could put it on a dyno. We have a place not to far away across the valley in Auburn.
Author:  Reed [ Fri Feb 10, 2012 12:12 pm ]
Both! :D
Author:  raPoM [ Fri Feb 10, 2012 12:33 pm ]
Im thinking about doing a baseline dyno on my truck,and then one after the 4bbl,HEI,Headers,and 4.56's are installed to see what kind of gains I get without doing any head/internal engine work.
Author:  Rug_Trucker [ Fri Feb 10, 2012 2:43 pm ]
I love reading any dyno stuff!
Rapom I would do an RV type head like I did for a friend's van.
Author:  raPoM [ Fri Feb 10, 2012 2:56 pm ]
I will be. Stock valves with a back cut,and just a casting flash cleanup and port match,then a cut to get 9-1. I was wanting to do a big cam,but I may just put something like the RV15m that Doc designed.I want to be able to run pump 87 at all times since its my daily driver.It should be plenty fun with the 4.56's,trak loc,headers and a TQ cam.
Author:  Rug_Trucker [ Sun Feb 12, 2012 7:10 am ]
We cut .060 off my friends van head. I "Street polished" the chambers. did the bowls. port matched the intakes. Actually went 1/8" bigger around them bigger than the gasket. Smoothed the exhaust. Didn't go bigger.
He had to run 89 until we put that head on. He runs 87 with no ping.
Author:  raPoM [ Sun Feb 12, 2012 8:15 am ]
Was this a mechanical or hydro lifter engine? If hydro,no problems with going .060 off the head?
Author:  ceej [ Sun Feb 12, 2012 8:34 am ]
Your going to run the RV15M RDP on a hydraulic top end? Problem. Don't run this profile for a hydraulic build. You will want a hydaulic profile. The lash ramps are too slow.
Or are you changing over to mechanical valve train parts? At .060", based on an uncut head to start, no problem. At 0.100" you may need to start looking at shorter mechanical pushrods. Not always.
2¢
CJ
Author:  raPoM [ Sun Feb 12, 2012 8:57 am ]
CJ-
Im actually looking into translating the RV15 into a hydro grind,based off of your recommendation :D I have been reading DadTruck's cam thread,and Josh makes a recommendation for a cam that is similar but on a hydro profile.
Author:  Rug_Trucker [ Sun Feb 12, 2012 8:27 pm ]
Mechanical head. Hydro's have some play. How much? I have no clue.
Author:  raPoM [ Tue Feb 14, 2012 3:06 pm ]
I need to figure that out. I hope I can raise my comp to at least 8.5-1 without issue.
Page 2 of 2 All times are UTC-07:00
