| Brake pedal height/position https://slantsix.org/forum/viewtopic.php?t=47854 |
Page 2 of 2 |
| Author: | Rob Simmons [ Sat Apr 26, 2014 7:31 am ] |
Quote: . Plus, when you use the adapter for the alum MC that spaces the MC away from the firewall that drops the pedal too.
Which is why it's confusing that it is so much higher.. Lou The stock pushrod in the picture is one I had in parts, not the one currently in the Dart. I will compare it to these once I pull the master out. Do you recall how much length you removed from your cut/tapped pushrods in case I am forced to go that route? I really don't have the time to "mess" with this much. I just wanted to replace the master and have some fun with it before I leave... I'm taking Chase to an autocross (SCCA) in Louisville tomorrow with the SRT-4. I was hoping to take the Dart as well, but that ain't gonna happen I guess. I'll report back once I pull things apart. Thanks. |
| Page 2 of 2 | All times are UTC-07:00 |
