engine build question
https://slantsix.org/forum/viewtopic.php?t=48151
Page 2 of 2
Author:  akbmotorsports [ Mon Mar 12, 2012 1:29 pm ]
did the swap and with #2 in #1 hole, got .020. so crank is ok.
i don't have any micrometers, so using a dial caliper i measured the two pistons that are out of the block, bottom of skirt to top of piston, and top of pin bore to top of piston, and i am convinced the piston is ok. so i believe i need a replacement rod, which will hopefully measure .010 - .013 longer. then all piston heights would be within .003.
i will remove the remaining pistons, mark the head as described and match the chambers to the bore. good stuff.
thanks, andy. 8)
Author:  Dart270 [ Mon Mar 12, 2012 2:15 pm ]
How the heck could those rods be off by that much - wow.
Author:  Doc [ Mon Mar 12, 2012 2:26 pm ]
My guess... it's a slightly bent con rod. Likely out of an engine / cylinder that got water in a bore, and was started. ("Hydrauliced")
Author:  akbmotorsports [ Mon Mar 12, 2012 3:12 pm ]
Post subject:  rod
Doc, if you may remember, the single rod you sent me a while back had a mismatched cap. i went through all mine and found the best fitting cap i had, the machine shop remachined it. the bearing to journal clearance was good, but maybe the machining was off. maybe bent, but either way i would consider it not usable. when i get another rod i will measure carefully before installing the piston.
have a great day, andy.
Author:  Doc [ Mon Mar 12, 2012 3:32 pm ]
Yes... aggresive resizing of the "big end" can change the rod's C to C... but .010 is a lot.
Author:  Dart270 [ Tue Mar 13, 2012 4:51 am ]
Oh, I thought those were new K1 rods. This is easier to stomach... knowing that these are used & reconditioned factory rods
Page 2 of 2 All times are UTC-07:00
