| carter leaking/boiling? https://slantsix.org/forum/viewtopic.php?t=49207 |
Page 2 of 2 |
| Author: | SlantSixDan [ Sat Jul 07, 2012 7:36 pm ] |
Quote: OK Dan what would you call the ones without the snorkel?
I guess it depends on context. I might call them "1961-'69 stock slant-6 air cleaners", I might call them "1961-'69 except '62 170 stock slant-6 air cleaners", I might call them "annular-intake silenced air cleaners", I might call them "air cleaners without snorkels". Quote: Got a pic of the open element air cleaner?
Yes, but it's thousands of miles away in storage. Here's a not-very-clear one. There was a shield spot-welded to the base plate extending vertically and outward to guard about a 150° section of the air cleaner from road splash propelled rearward by the radiator fan. The rest of the element had no guard or cover.Quote: What problem did they cause?
None that I know of. The 1962 170 item was referred to as an unsilenced air cleaner, and yes, they are considerably noisier.
| Author: | Rug_Trucker [ Sat Jul 07, 2012 7:43 pm ] |
Thanks. If my monitor wasn't so dark That pic would be good. I read there was some problem caused like a "flat spot." I thought they were referring to the mushrooms. Annular sounds like a Holley thing. |
| Author: | SlantSixDan [ Sat Jul 07, 2012 7:48 pm ] |
Ahhh! I know what you're thinking of. It's the other way round: if an air cleaner with a snorkel is installed wrong, it can cause a flat spot. See here. |
| Page 2 of 2 | All times are UTC-07:00 |
