| Can't seem to keep a good fuel/air ratio https://slantsix.org/forum/viewtopic.php?t=49257 |
Page 2 of 2 |
| Author: | SlantSixDan [ Sat Jul 14, 2012 2:28 pm ] |
Loose spark plugs aren't good. What plugs are you running? Did you remove the metal ring washers from them before installation? |
| Author: | Brovender [ Sat Jul 14, 2012 2:47 pm ] |
I'm using the NGK plugs you recommend, can't recall the product # but they're the right ones. And yes I removed the metal rings. |
| Author: | SlantSixDan [ Sat Jul 14, 2012 3:09 pm ] |
Tighten them up to the specified torque, but I don't think that's the main cause of your problem. I still think the problem is probably in your carburetor. See my earlier comments (float, etc.) |
| Author: | Brovender [ Sun Jul 15, 2012 11:15 am ] |
Thanks Dan! |
| Author: | Brovender [ Sat Jul 21, 2012 8:40 am ] |
Dan, I checked my float and all is fine with it. I'm having the problem again with constant stumbling. The car has always had a little miss to it. When warm it wants to cut off whenever I am in gear. I'll give it a good rev and it'll backfire through the carb, then smooth out and stop missing and run great. Is this a stuck valve? |
| Author: | SlantSixDan [ Sat Jul 21, 2012 10:17 am ] |
Quote: Dan, I checked my float and all is fine with it
I'm not yet convinced. How'd you check it?Quote: I'm having the problem again with constant stumbling. The car has always had a little miss to it. When warm it wants to cut off whenever I am in gear. I'll give it a good rev and it'll backfire through the carb, then smooth out and stop missing and run great. Is this a stuck valve?
Probably not.You may be due for a new carburetor; send me a PM if you're in the market. |
| Author: | Brovender [ Sat Jul 21, 2012 10:48 am ] |
PM sent! |
| Page 2 of 2 | All times are UTC-07:00 |
