install?????s
https://slantsix.org/forum/viewtopic.php?t=49573
Page 2 of 2
Author:  hantayo13 [ Wed Aug 22, 2012 6:09 pm ]
right now it all apart with trans shaft pilot thru clutch plate, but it wont slide onto splines eeeeeeerrrrrrrrrrrr
Author:  ceej [ Wed Aug 22, 2012 6:32 pm ]
I spent a full day swearing at a 345 Corn Binder. Lined the clutch up three times, checked to make sure the tranny was in gear multiple times.
Then discovered the neighbor kids had been playing around and put the transfer case in two lever neutral.
Thunk.
Transmission in gear, transfer case in gear. Fresh clutch alignment. Did it by myself with an old wrecker for a cherry picker. Nice to have the extension on the tow truck to move the engine back and forth.
I feel for you! It's frustrating to work alone.
CJ
Author:  Mroldfart2u [ Thu Aug 23, 2012 1:22 pm ]
The way you need to do it... :lol: :lol: :lol:
Shake It
Author:  hantayo13 [ Thu Aug 23, 2012 6:02 pm ]
lil brother came over ...we shook it for bout two hours...still not going together ...I went looking for longer bolts 2" x 9/16....local hardware has 1/2 and 5/8...so I get to ride to CAT dealer tomorrow .....several of the local curvy roads just been paved atleast ride will be nice
Author:  Ross [ Thu Aug 23, 2012 8:46 pm ]
I did the opposite of you (tranny back in after throwout pivot broke). It was a pain getting it back on with two guys. make sure that both of your descendants are disconnected from the t case so you can soon it. I'd install the engine, flywheel and clutch before installing the engine back in the truck just so you can make sure it's aligned and everything is on right. Then try to install the engine and since the output shafts are free you should be able to turn them so you can get the input lined up. Maybe a little lift on the front of the tranny will help. Try raising and lowering it when you try putting the shaft in, it could just be at a bad angle.
Author:  tyb525 [ Sun Aug 26, 2012 8:12 pm ]
I installed my rebuilt A833 OD by myself, it slid right into the bellhousing no problem.
Have you turned the output shaft on the transmission, with it in gear, to try and get things lined up?
Author:  hantayo13 [ Mon Aug 27, 2012 5:40 am ]
tyb525
is 4 wheel drive big tran/tranfer together /driveshafts still on ....been turning engine
right now clutch plate loose and only wants to go on about 1/8 inch stops dead no further
Author:  hantayo13 [ Mon Aug 27, 2012 5:56 pm ]
pulled engine....clutch////disk slides on shaft easily.....WTF?????
Author:  hantayo13 [ Wed Aug 29, 2012 5:48 pm ]
took wife's 05 scion xb in to have codes erased..had to use wrench as hammer on dealer only solidnoid ...lights all off in dash ....paul bend up 2 1/2 duel down tubes,flanges & gaskets...dug thru bow of clutch pilots and found two ...Mac gave me one ...clutch is back on engine...hopeing it slides together this time
Author:  hantayo13 [ Sat Sep 01, 2012 7:13 pm ]
well clutch installed on flywheel with throwout bearing/arm...lowering engine into place ,it lunges forward almost cutting tip of left pinky off between alt /rad support ouchy ......off to party rest of weekend....happy holidaze to all
Author:  slantzilla [ Sat Sep 01, 2012 7:37 pm ]
:D :D :D :D :D :D :D :D
Author:  hantayo13 [ Thu Sep 13, 2012 5:22 pm ]
well trans is bolted together to engine .....WOW .....nephew came over and we shook,rolled ,pryed with 5 foot alum rod bent it some.....finally got the longer bolts started,,,,1/8 turn at time on each one all the way in......putting left mount together ,step on rim,,,,PISSSSSSSSSS, yyyea you guessed it popped the valvestem one step forward ,two back,one to side .....just dancin' thru life .....ooooooo yyea shop called and said bike was fixed , he just ran his 30s something turbo 80 ci at 150 mph on the salt, I got to sit on it ....he is FFFFFin' crazy....but I would give it a go LOL......cats and mufflers ordered for 2 1/2 stacks off the dultra duel duels,got dumps going till it goes to shop after it runs ways to go yet
Page 2 of 2 All times are UTC-07:00
