It is currently Wed May 20, 2026 10:52 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Sun Jan 20, 2013 7:30 pm
The frame holes where the steering gear is mounted are slightly oversize. Center the wheels, then loosen the steering gear and move it as required to center the steering wheel. If you cannot center it, check the frame for bends/damage. The FSM gives the checking dimensions in the "Frame" chapter. Use a plumb bob to project the checking points onto the floor, and make the measurements there. You can project the points onto a sheet of paper or cardboard, or just put some pieces of masking tape on the floor. iirc the steering columns on trucks do not use a master spline, so the steering wheel can be relocated relative to the column.
Ken
Thanks Ken,
I wil check all of that out in the Spring When I get the Ramcharger out of storage.
I was Not aware that the Chrysler Truck Wheels / Shafts Were Not Master Splined.
I am pretty Sure it was Not Hit.. There is No Frame or Any other Body Damage.. I am the third Owner... My Dad Bought it from the Original Owners' estate.. It Was pretty Original when I got It 'cept for paint.
PostPosted: Sun Jan 20, 2013 8:29 pm
The column in my '86 does have a master spline..
63 Valiant 200
64 Dart 270
73 Fury II
84 Cherokee 2 dr
86 Dodge W-150
73 Volvo 144
74 Volvo 145
81 Volvo 245
