It is currently Thu Nov 26, 2026 5:12 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Fri Jan 04, 2013 8:04 pm
Im doing it hot running, as far as the clearances im unsure what they were set at and when, some of them were super loose and clacking really bad so i barely tightened them, but i know which ones they are so I can adjust em back if needed.
Also how many full turns should my idle screw be turned from no idle for the car to start and run properly?
66 Plymouth Valiant 2door. Slant 6 225, 3speed
PostPosted: Fri Jan 04, 2013 9:57 pm
Site Admin
Fallon... OK. Mike might be down in your neck of the woods sometime.
Tristen might be able to help you out. He's in Reno, but he's pretty busy these days.
Have you been to the FAQ associated with the engine section of this web site? If not, give it a cruise. There is information about the various carburetors available for the slant six.
The idle mixture is best set with a vacuum gauge. A good place to start is 1-1/2 turns out with any carburetor. It'll at least try to idle. Do not force the needle closed. Be gentle or damage can occur. Turn it in until the idle slows, then turn it out until the idle cleans up. Go another 1/8 to 1/4 turn out, and you'll be int the ballpark.
Do you have feeler gauges to check the valve clearances?
If you do not, then you may be chasing your tail. Go buy a set. You may need somebody to show you how to do this. I won't be in Fallon until I pull through for MATS in March.
To adjust valves hot, you must have a set of feeler gauges, and know what the "Feel" is to use them. So in a nutshell, here it is:
Running hot, this means the engine is fully up to operating temperature. If possible, before pulling the valve cover, drive a few miles, pull into your work area, shut down, pull the valve cover right away, connnect the vacuum lines, and have the pcv connected, or the port for it plugged.
Idle the car as best you can. Slower is better.
Identify the intake and exhaust ports. Hopefully you know which is which.
The valves line up with them. Exhausts to the outside, intakes inside. In the middle, there are two intake valves next to each other.
Set the intake valves running to 0.010", and the exhausts to 0.020"
This is done by applying the correct feeler gauge to the gap in between the rocker and the valve stem. If the feeler gauge won't go in, loosen it, if it slides around freely, tighten it. Always measure with the wrench removed from the adjuster. It makes a difference.
It sounds like you could use some help. I've been setting valves for forty years, so it's second nature to feel for how the gauge moves around in there. It's something that is taught. Not something that can be downloaded. The amount of loosening is very small to open the valve up, conversely, it takes very little to tighten the valve to get just the right resistance on the feeler gauge. We're not talking an eighth of a turn, more like a nudge.
Do not use a brass .010" Feeler gauge for your valves. Use the steel one. Brass will not stay at dimension long when adjusting valves.
I certainly hope this helps. Hook up with somebody that can help you with this, then get in there and feel what they've adjusted. It'll help a lot. :D
CJ
PostPosted: Sat Jan 05, 2013 12:37 am
Thanks Ceej for the tips, unfortunatly for me I do not know anyone that has worked on one of these engines before and most of this has been learning as I go and trying to figure it with what help I can get from online research and such like that.
I do not have feeler gauges, I do not have a vacuum gauge, basically everything is done by look and guess. I have not touch the air/fuel mixture screw at all on the carb.
I would really like to be able to get with someone in my area that knows more about this, because I love this car and have been doing my best to fix it up and get it running right
PostPosted: Sat Jan 05, 2013 7:19 am
A vacuum gage and set of feeler gages probably won’t fully kill a Jackson; these are basic diagnostic tools every tool box should have.
PostPosted: Thu Jan 10, 2013 3:38 pm
Thank you guys for the help, I still havent got a vaccum gauge just yet, but I did get some feelers and did the valve adj. correctly and it runs and works so much better now! :D
PostPosted: Thu Jan 10, 2013 4:14 pm
Good work...
A SL6 is pretty easy to work on so don't be afraid to "dive-in".
Users browsing this forum: No registered users and 23 guests
