| Cam https://slantsix.org/forum/viewtopic.php?t=50936 |
Page 2 of 2 |
| Author: | slantsik [ Sun Jan 27, 2013 2:05 pm ] |
| Post subject: | Thanks. |
Thats great ,Thanks . Good Idea on getting the lash a bit tighter for less noise. I did find a chart somewhere here,that compared many cam grinds.Ill see if I can post a link. http://www.hal-pc.org/~bwhitejr/Slant_Six_Cams.pdf There we go. Quote: There is way more to cam lobe designs... then the duration & lift numbers you see.
Yes ,after reading the article I posted above, I have a better understanding .DD Once again we appreciate the help. Brendan. PS.Ben we are on flood alert on the tweed river! water is a foot from the top of the levy bank. |
| Author: | SlantSteve [ Sun Jan 27, 2013 9:51 pm ] |
Hey guys,I'm in OZ as well,have been looking at cam options locally for a very similar build have you tried Waggotts? I sent them details a while back but haven't heard back as yet,perhaps 3 customers combined would inspire them into action? I have experienced the pentastar parts cam (or at least that's what they told me was in the engine they built for my parents VC) my experience is that I wouldn't bother again,it runs decent,but nothing special and its now starting to foul #1 plug,hence Im building a replacement motor for it .Years ago I ran a heatseeker cam I bought from Watsons ,it was a very mild grind that was far superior in a mild street motor. There is also Camshaft engineering in Brisbane,I have an LPG 318 stroker they did the cam for me with good results.Failing all that,perhaps we could do a group buy from Ersons and save with combined shipping? Stay dry guys,Cheers,Steve |
| Author: | slantsik [ Mon Jan 28, 2013 10:05 pm ] |
Hi Steve. I wont be needing any camshafts soon. I recently recieved one from Hemi Performance ,but it was the wrong one. called them today and they are sending the correct one down as I type this,no Drama. I have not tried waggots.wade etc. In fact I have never had to buy a cam before this one. The cam I got(am getting) from hemi Performance is supposed to be a torque type cam ,good for towing etc. Now that doc has posted all the relative info here, I am interested to see if somebody in OZ can grind the same as the two he showed us,and for how much$?? Where did you go Ben? Bye Brendan. |
| Author: | Brussell [ Sun Feb 03, 2013 3:45 pm ] |
So i showed the two cam designs doc posted earlier in this thread and i was advised they are hydraulic lifter cams? Is that right? If so i guess i am back to square one. |
| Author: | DusterIdiot [ Sun Feb 03, 2013 4:06 pm ] |
| Post subject: | Whiskey Tango Hotel? |
Quote: So i showed the two cam designs doc posted earlier in this thread and i was advised they are hydraulic lifter cams? Is that right? If so i guess i am back to square one.
If your cam regrinder told you that, time to take the business elsewhere, quickly...no those are mechanical grinds.-D.Idiot |
| Author: | Brussell [ Sun Feb 03, 2013 11:24 pm ] |
Thankyou, haha that is what i thought. |
| Author: | Brussell [ Mon Feb 04, 2013 3:01 pm ] |
| Author: | Doc [ Mon Feb 04, 2013 3:46 pm ] |
"Deflection" is valve train deflection, from the lifter bores, rocker arms, valve guides, etc. The "Hot Lash" settings tells me that these are mechanical cams. DD
| Author: | Brussell [ Wed Feb 06, 2013 7:32 pm ] |
Thanks again Doc, I found another supplier locally who knew it was a mechanical cam straight away. Fingers crossed for a better result. My final question is that is a cast iron cam acceptable for my application? Most aftermarket cams I have seen advertised are steel billet etc that's all. |
| Author: | DusterIdiot [ Wed Feb 06, 2013 9:31 pm ] |
| Post subject: | Yep... |
Quote: My final question is that is a cast iron cam acceptable for my application?
Iron cams were good for a trip to the moon and back in mileage terms in stock cars...never had a problem with a regrind on the stock blank or new iron blank either...billet would be good if you are going to try a roller cam profile for HP applications (not like these blanks are on the shelf...), but is not necessary for daily driving and regular dragstrip uses.-D.Idiot |
| Page 2 of 2 | All times are UTC-07:00 |
