| Pistons Replacement https://slantsix.org/forum/viewtopic.php?t=51019 |
Page 2 of 2 |
| Author: | Sprag [ Wed Feb 06, 2013 5:22 pm ] |
How about head gasket fire ring issues? I just did this head/block mock up on mine today and checked the gasket fit too. I noticed the fire ring on the generic Felpro gasket might actually protrude if I were to go .060" with a oem style chamfer atop the bores. I'm only going .040" and it should be fine but it looks close. Where does the 'big bore' gasket come into play? |
| Author: | jhdeval [ Wed Feb 06, 2013 5:37 pm ] |
Gasket fire ring? |
| Author: | Sprag [ Wed Feb 06, 2013 6:13 pm ] |
Quote: Gasket fire ring?
Yah, that round silvery looking thingamabob whatchamacallit doohicky that seals around the top of the bore/chamber.EDIT:
| Author: | jhdeval [ Wed Feb 06, 2013 7:50 pm ] |
Never knew it was called that. It is going to be a few months before EVERYTHING is done so no test fitting yet. |
| Author: | Sprag [ Wed Feb 06, 2013 8:30 pm ] |
I don't know if there's a proper name but that's what I've always called them. |
| Author: | jhdeval [ Thu Feb 07, 2013 6:38 am ] |
Be careful with the 83 head as I understand it the lifters were changed to hydraulic. I know I saw both mechanical and hydraulic cams but I am not sure you can use the adjustable rockers with hydraulic lifters or not. |
| Author: | DusterIdiot [ Thu Feb 07, 2013 7:29 am ] |
| Post subject: | You can't. |
Quote: I am not sure you can use the adjustable rockers with hydraulic lifters or not.
They won't oil properly causing issues, so in a nutshell, no you can't.-D.idiot |
| Author: | jhdeval [ Thu Feb 07, 2013 7:54 am ] |
Thank you for the clarification Duster Idiot. I did not think you could but I was not sure. Spragg had mentioned he had test fitted both a 66 and 83 head. I knew there was a difference between the 2. |
| Author: | Sprag [ Thu Feb 07, 2013 8:38 am ] |
I think I'm OK by slipping just the head between the existing stuff, the original mechanical rockers/shaft/pushrods/hardware will stay. I think the only real/major difference is I won't be able to pull the lifters with the HYD '83 type head bolted on, I don't think they will fit up through the smaller oil drain-back area over the lifter galley. |
| Author: | robertob [ Thu Feb 07, 2013 4:02 pm ] |
valve cover is different. |
| Page 2 of 2 | All times are UTC-07:00 |
