| SSGPohlman 84 D150 https://slantsix.org/forum/viewtopic.php?t=51446 |
Page 2 of 5 |
| Author: | zorg [ Mon Mar 25, 2013 9:01 pm ] |
Looking good! Nice attention to the little details, that makes the finished product so much nicer. Also, I LOVE your use of the car wash stall to swap in the HEI!!! |
| Author: | Ssg Pohlman [ Sun Mar 31, 2013 9:21 am ] |
| Post subject: | Data plate |
Well I ordered a fender so I figured I'd find the paint etc. So I had....hmm...an acquaintance Codes on the left BUA, ?KG, DCC -A833 (nonOD?), DJB 3300# front axle, DMD 3.54 axle, DRA CHRY 8.25 (axle not the size of my cherry! CODE RIGHT: DRE -rear axle chry, OSA limited slip, PC3 primary color, QS7 secondary color, SKA, SNF. |
| Author: | Ssg Pohlman [ Sun Mar 31, 2013 7:56 pm ] |
| Post subject: | As promised |
![]() ![]() So now I know a bit more about the truck, just figuring out the paint.... |
| Author: | Ssg Pohlman [ Sat Apr 06, 2013 10:14 pm ] |
| Post subject: | Parts! |
Well boredom and envy strikes yet again! So I ordered some parts for the truck which kind of seals the deal for going turbo. Aeromotive 13301, 3-65 psi bypass w 1:1 rise rate. 3 ports all 3/8 NPT Autometer 1471 gauge 30hg/20psi (wh1c factory wastegate is 17 so went 20 just in case i go that high and use the wastegate.) Autometer 15198 dual a pillar mount fits 86-93? ram look for under diesel New holley nitrophyl floats center hung percy 15001 adjust a jet (will do a full write up on this, take one for the team) jet extentions (not sure if needed, @$8 ill go with it) russels billet fuel block (to divide the oil line for the turbo) RUS-650380 has 3 ports all 1/2" NPT and one 1/8" for a gauge. This is to run the line up through the front oil cooler before going to the turbo. So that was 375.69 right off the top. I think i have 15 in the holley adapter (MRG-1937 to mate 2300 to super6 intake), and 100 in a holley 2300 500cfm (not even rebuilt yet), and 200 in an innovatice LC-1 WBO2 so for those keeping count, that is roughly $700 J-pipes? I know pishta runs one and seen it but what I dont know is 2.5" or 2.25". I asked elsewhere how much you could bore the stock mani, its been done to 2.25, but is that the max? Still on the list: Fuel lines to and from, fuel pump, turbo flange, manifold flang, J-pipe, oil cooler, carb hat, cold piping, BOV, Misc lines, most likely switch from 833 OD to 904tf. small items here and there as well...add downpipe.. on and on it goes. And Ill throw this in here, Ive searched and not found, TURBORAM-going to pick your brain since i dont see a build thread for your truck! |
| Author: | Rick Covalt [ Sun Apr 07, 2013 4:45 am ] |
Turboram's truck would be listed under "rocket-ship" |
| Author: | MotoGrey [ Wed May 15, 2013 9:14 pm ] |
| Post subject: | Great Truck SSG |
Nice work and I like your attention to detail. Can't wait to follow your turbo work. Ok now I need to jack this thread so someone can teach me how to put pics of my 84 D-100 that I am just finishing with installing my new engine in according to the DadTruck specs. Thx, Ray |
| Author: | Ssg Pohlman [ Thu May 16, 2013 11:45 am ] |
Load them to a server like imageshack (I use it) then it will give you the "code" for posting them here. Usually you just highlight and copy the code from the "forum" box. It's easy once you get the first one. And there's and FAQ on how to as we'll somewhere. Lets see that D100!! Pohlman |
| Author: | Junior [ Thu May 16, 2013 4:29 pm ] |
looking good, i love the stance and the blackout treatment on the front end. keep up the good work. |
| Author: | Ssg Pohlman [ Wed Jul 03, 2013 4:04 pm ] |
| Post subject: | Alive!! |
Well the time has come and I made it home. Haven't been home a week and already turning wrenches. I'll add the links later but I changed to the all black dash and added my two pod pillar mount w boost and wideband installed. You can click on an older picture link to get to them. That's right, soon, I'll be in boost! |
| Author: | Ssg Pohlman [ Sun Oct 27, 2013 4:35 pm ] |
| Post subject: | Been a while |
As the subject goes, so it's time for an update. I'll keep it condensed as best I can. Full time school at 15hrs, drill weekends, kids almost every weekend etc etc. So what I have managed. I did pick up the holley 350 from Wayne and added a Percy adjust a jet to it. Which for me was great, flog it and adjust as needed. Dialed right in w the wideband. Then decided (don't know why) filled up w 17 gal of E85. Having wideband I dialed it in rather fast. Ran great until it started to turn cold so I went back to the carter bbd. However it has started to eat oil so I set on a quest to find and engine to rebuild while I could still drive to minimize down time. Thanks goes out to Wayne (Wveneble) and John (dadstruck) for locating one. Drilled this weekend by the Indianapolis airport so Sat. After drill I drove over to ohio and picked up a "rebuilt" engine. Seller claimed he was "almost positive it had been bored and thinks it has a diff cam in it. Paid, loaded and drove home today. Stopped by Wayne's house to let him see it. Pulled the valve cover and it's beautiful clean. Block checks out as an 82 while Wayne looked up the head as a 79-80? (Forgot already). So it is a mechanical engine. Can still see the numbers on the deck so that leads me to believe the block received no milling. So got it unloaded and unscrewed the oil filter, all squeaky clean. Then I had a thought, all the spark plugs are missing so I wanted to see the walls and pistons. Flashlight in hand I looked in, forgot about stamping a in the top of pistons and found that the engine has in fact been bored .040 over! So far so good. Some things figured and still more unknown like if the head was milled and if in fact a diff cam was put in. Stop rambling, couple weeks and I'm going to take the weekend to just drop the new engine in and run it. Keeping my old one in case. Fingers crossed it works out and I won't need my old engine for another 200k miles. (Currently 194k) more to come..... Edit: so fix me if I'm wrong but with bore of 3.44 and stroke of 4.125 is 230.03 CID? Accounting for the .040 over? |
| Author: | emsvitil [ Sun Oct 27, 2013 6:52 pm ] |
I get 230.0286705 cuin or 3769.594838 cc |
| Author: | wjajr [ Sun Oct 27, 2013 8:35 pm ] |
230.0286705 cu in = 7.9664US pints Round it up to a gallon... |
| Author: | Ssg Pohlman [ Mon Oct 28, 2013 4:56 am ] |
Quote: 230.0286705 cu in = 7.9664US pints
I'm currently taking fluid power for my associates and thought the exact thing!!Round it up to a gallon... I'll be running a full gallon of fury! |
| Author: | DadTruck [ Mon Oct 28, 2013 5:41 am ] |
glad that is worked out on the engine over in OH, if you decide to do machine work on the existing engine,, Ed's Machine Shop in Morresville did fine work,, |
| Page 2 of 5 | All times are UTC-07:00 |
