It is currently Sat Nov 28, 2026 3:26 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Tue Apr 09, 2013 1:32 pm
Uh, I don't run ZDDP plus in any motor I own or work on. My recollection was that the new oils are formulated to satisfy the cushioning and shear requirements of the oils used in flat tappet days, so new oil is fine and ZDDP additives are a marketing scam.
PostPosted: Tue Apr 09, 2013 2:03 pm
My recollection was that the new oils are formulated to satisfy the cushioning and shear requirements of the oils used in flat tappet days.
Don't bet the farm on that. Probably on a stock cam you'll be OK. Get lumpy with high spring pressures? You will be running a magnet through your oil galleries cleaning out shrapnel.
I bought all the STP oil stabilizer I could get my hands on. QT bottles of 30W with lots of ZDDP. It has been out of production for a few years. I got it for all cam, and new engine break ins. I will run deeezel in them after 500mi.
PostPosted: Wed Apr 10, 2013 12:20 am
1963 AP5 Valiant 225 PB 904 Stock except extractors & 2 1/4 inch exhaust.
1962 S series valiant 225 PB auto. factory every thing. Full restoration job.
Currently on hold till AP5 is on the road.
PostPosted: Tue Apr 16, 2013 7:12 pm
Hmm...I was thinking of getting the cam reground. Lift would be .437". Is that too much list for modern oils?
PostPosted: Wed Apr 17, 2013 10:47 am
A few years ago I had a 1964 225 cam reground and installed it in my brother's 1983 Dodge van. To break in the cam we used straight 30 weight motor oil (Chevron brand, I believe) and the cam was run with 5W-30 oil after that.
My brother drives the van hard. Several thousand miles later we ended up pulling that cam because the cam gear locating dowel sheared off the front of the cam. During that process I discovered that I had installed the rocker arm shaft upside down so the valvetrain was not being properly oiled. The cam looks perfect other than the broken dowel. No ZDDP or any other additive was ever used, even during break in. I fully intend to replace the dowel and reuse the cam with resurfaced lifters.
Personally, I will continue to not spend my money on additives for oil or transmission fluid.
PostPosted: Wed Jun 26, 2013 6:26 pm
fwiw Mobil-1 0W40 European Formula has ~1200 ppm ZDDP.
Ken
Users browsing this forum: Ahrefs [Bot] and 9 guests
