| Points Distributor meltdown........ https://slantsix.org/forum/viewtopic.php?t=51835 |
Page 2 of 2 |
| Author: | 64DartGT [ Wed Apr 24, 2013 10:09 pm ] |
Ok will check with Napa to see if they have them....ask for Bluestreak......? http://www.napaonline.com/Catalog/Catal ... 0171068494 |
| Author: | Aggressive Ted [ Wed Apr 24, 2013 10:10 pm ] |
Yes, like mentioned, that is all I run in my 440's |
| Author: | 64DartGT [ Wed Apr 24, 2013 10:13 pm ] |
Is the link above a set with Bakelite....? |
| Author: | Aggressive Ted [ Wed Apr 24, 2013 10:23 pm ] |
Yes, it sure likes it .......would need to see them in person to be sure. If you can see the weave and the ply build up, then yes..... I see Harley Davidson uses the Blue Streak ones with a bakelite cam follower. Borg Warner makes them too....for Chevs and Toyota's. I just did a quick search. Our local Auto Parts here in Black Diamond has them....and I just got hooked on them especially on high rpm engines. The white nylon ones wont hold a gap very long.....before they go out of tune. |
| Author: | 64DartGT [ Wed Apr 24, 2013 10:27 pm ] |
Ok Ill look at these and see if I see the weave and the poly build up on them at the parts store....Thanks again for your help and advice..... |
| Author: | 64DartGT [ Wed Apr 24, 2013 10:47 pm ] |
http://www.ebay.com/itm/170867222784?ss ... 1497.l2649 This looks like a set of points like were mentioned above.......? |
| Author: | 64DartGT [ Sun Apr 28, 2013 5:10 am ] |
Looks like Bakeite.......
| Author: | Aggressive Ted [ Mon Apr 29, 2013 10:38 am ] |
Yep! That will last a long time and not melt. Just smooth the follower with some 600 and put some synthetic grease on it.... It will take a lot of heat and will not melt like the white nylon. |
| Author: | 64DartGT [ Mon Apr 29, 2013 1:11 pm ] |
Thanks Ted for all your advice on the Bakelite points........... |
| Page 2 of 2 | All times are UTC-08:00 |
