It is currently Sat Nov 28, 2026 4:06 pm
 Post subject: Re: No.
PostPosted: Wed Jun 19, 2013 11:48 am
Hmm, I noted where the super six has larger exhaust valves.
So,.. that begs the question of,.. Does the casting number of 4104362 "exclude" the optional feature of larger super 6 valves.?,.. or did the factory also put the optional super 6 valves into this casting numbered head via machining for the super 6 upgrade ?
I am thinking in terms of original specs when I ask the above question.
PS I have a super 6 two barrel intake on my parts shelf and assume there is little benefit to make it part of my head replacement package without having the larger valves to benefit breathing regards to horsepower.
Super six heads are the same as regular heads, i have a couple and they have that standard size valves stock like their 1 barrel counter parts...it's the exhaust pipe that is larger.
The upgrade to the stock 2 barrel on a standard engine with the larger exhaust pipe does have measurable power gains but will be limited by the cam and drivetrain choices...plug and play it's maybe 10 hp and a few ft.lbs of torque...which if matched to a suitable vehicle build can change the shift points and might garner a little bit better gas mileage.
There are more benefits to adding more compression and a cam change to make the most out of the setup I know that I was able to get roughly 150 hp out of a 1979 slant six with super six and 350 cfm Holley carb, 2.25" tailpipe, 9.6:1 compression, aftermarket cam, stock head and valves.
Super six heads are the same as regular heads, i have a couple and they have that standard size valves stock like their 1 barrel counter parts...it's the exhaust pipe that is larger. -D.Idiot
I had my local O'rielly auto look up the part numbers for 1979 single barrel and then the two barrel and the book gives different part numbers? What is that about if they are the same? G
PostPosted: Wed Jun 19, 2013 12:28 pm
There are two distinct heads available in the BL "peanut plug" head era 1975-1987... Basically: The most common head is the "447" head which has a hole in the casting just past the #6 exhaust runner that is where the smog charge tube or air pump is piped into the exhaust to provide more oxygen to complete the burn of exhaust gasses...the other head "600", does not have this hole or casting (much more desirable, and very rare to find), and is for vehicles in areas that did not require this equipment. The smog pump head design is the most common to find on 1978+ vehicles and pretty much 100% of trucks after 1981 (note these will have updated casting numbers).
O'Reilly's webpage notes these heads as part number 2D09 for the non-smog equipment head (no hole), and 2D12 for the smog equipment version (Hole).
PostPosted: Fri Jun 21, 2013 5:41 am
Please know that I am not doubting the earlier information given me, of,…..
""Super six heads are the same as regular heads, i have a couple and they have that standard size valves stock like their 1 barrel counter parts...it's the exhaust pipe that is larger.""
I very much appreciate the answers received. I should clarify that I had the parts man look up this info for the exhaust valves and not the cylinder head.
I find the O'rielly parts book asked this question==> Two barrel or Four barrel? To my dismay, the parts book gave two different numbers for exhaust valves.
With two different part numbers I wonder of differences if any.?
PostPosted: Fri Jun 21, 2013 4:55 pm
I had a hard time not attempting to buy the block also.
You could always revisit the yard in a couple of weeks and make a shamefully low bid on the block if it is still there! :D
The only slantsix that came with a four barrel, was an optional engine performance package, the Hyper-Pak engine in the early sixties Valiant. You may have misinterpreted your O'Reilly regarding ex. valves for a four barrel SL6.
Olaf
Aspenized
 Post subject: Yep...
PostPosted: Fri Jun 21, 2013 5:29 pm
An even then it was a dealer installed item over the counter, not a factory "here's your new car" in 60-62. I would be curious about that as well...If going oversize you can get those from various sources. He should also have given you a part number and manufacturer to ensure he's not blowing smoke up your muffler (all the major supplier/manufacturers catalogs are on line- Manley, SI, etc..). Some manufacturers do have the 1.70/1.44 valves listed in their catalogs for purchase.
In referring back to the OEM parts catalog they list 3 replacement valves for the slant six cast crank engine head in the event of a valve replacement and seat regrind: standard/ .005 O/S, and .030 O/S...
Too bad since a month ago, a former board member up in Portland was selling one of his last heads with chevy valves for $100 on craigslist... then you could have a hi-po head. On a stock engine it doesn't make that much of a difference.
PostPosted: Fri Jun 21, 2013 5:37 pm
Just a thought, were the SL6 truck engines ever equipped with rotating exhaust valves? If so, that may explain a different part number.
Olaf
Aspenized
PostPosted: Sun Jun 23, 2013 10:54 am
Olaf
Olaf, after finding the condition of the head in so far as anticipated mileage,.. the block became in my evaluation suspect. Therefore I would not be interested in buying the block.
TO ALL,..... NOW BACK TO MY ORIGINAL QUERY.
The reason I do not have any idea of the head I purchased insofar as super six or not is,.... the intake/exhaust manifold was removed/sold, including the head pipe. So that is why,.. I asked the question.
Therein explains why I asked the original question of,...
"""Is there any difference in valve size between two barrel and single barrel""" ie: (super six vs. standard)"
I earlier gave the casting number of this head and it proved to be a 1979. (Also, I removed it from a 1979 D100).
BTW, I do have an answer from a very well informed forum member.
It is/was however in contrast to what O'riellys parts counterman had told me.
I am hanging with Duster, the informed forum member, mainly because he and others have a ton of experience here.
Thanks G
Users browsing this forum: DuckDuckGo [Bot] and 9 guests
