It is currently Sun Nov 29, 2026 6:54 pm
Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2
PostPosted: Tue Jun 11, 2013 2:35 pm
Rebuilding carb tonight. Where can I get a new choke rod thats not bent? Cant seem to find it in any auto parts store. More importantly where can I find the clips the keep the rods secure?
PostPosted: Tue Jun 11, 2013 2:48 pm
Everything you need is in the CarbsOnly electric choke conversion kit #1234. See HERE. These may be available at your local Napa, see HERE at the end of the thread, or go straight HERE for the Napa part number.
These kits are significant improvement over the original choke thermostat setup and are more reliable, more tune-able, and available NEW. They also come with the clip you need to hold the choke thermostat rod onto the carb.
PostPosted: Tue Jun 11, 2013 8:11 pm
Here's a link to what looks like the same carb as yours on ebay...
http://www.ebay.com/itm/AUTOLINE-C7385- ... 6493825%26
1984' Dodge D150 Utiline Bed
Slant 6 225, Holley 1920 Carb
A833 4 Speed O/D Transmission
PostPosted: Wed Jun 12, 2013 7:31 am
Car Model: 1977 B100 Van
I would avoid remanufactured carbs at any cost.
If you need a new carb., search for NOS, never used and never messed up with unit like this one:
http://www.ebay.com/itm/NOS-Holley-1-57 ... 0857982438
"Hey, I like that paint job you got. What they call that--sorta a cross between Piss Yellow and Puke Green, ain't it?" -- Bob Falfa
PostPosted: Wed Jun 12, 2013 9:26 pm
Well it took an entire day but I rebuilt the carb... I think. The ball was stuck as some of youguys have mentioned. Now I am having trouble remembering where all the hoses and vac lines go. I feel like im missing something. Anybody have a pic or link to info just to confirm everything is where it needs to be? I ask because my truck wont even start for a sec now :roll: draining gas tank in the morning.
PostPosted: Thu Jun 13, 2013 5:08 am
'84 diagram at the end of this thread:
http://www.slantsix.org/forum/viewtopic ... b730ad0eb1
and get a factory service manual ASAP
(http://www.slantsix.org/forum/viewtopic.php?t=15780)
PostPosted: Thu Jun 13, 2013 7:39 am
Its a fuel problem now. Carb was completely dry after taking it off this morning. Cant even suck fuel from the line like i could before. Its got a new pump and filter. Thoughts on why?
PostPosted: Thu Jun 13, 2013 7:45 am
Plugged in tank pickup screen
Rusted metal fuel line/s, a simple pin hole will cause you to lose suction.
Rotted rubber lines and connections, there may be a few of these that are cracked, again loss of suction.
One of the best ways to start a vehical after sitting for a time is to use a gas can as your tank. Run a new rubber line directly from the pump intake into the gas can with fresh fuel. Once everything is proven to run properly then you can sort out the fuel tank and lines.
Mattelderca
PostPosted: Fri Jun 14, 2013 11:47 am
Ill second the cracked or broke down lines. My truck had them on the back by the tank. If I remember right there are at least two if not three. Maybe 8" long to get from tank to hard line hoses, real pita to change too but doable.
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
PostPosted: Fri Jun 14, 2013 1:08 pm
I swear there is a curse on this truck. I did as told, temp fuel line in gallon jug of gas... nothing... unscrewed fuel line from pump and cranked... nothing. .. reversed (or maybe corrected?) Valve in fuel fitting for carb... we have gas!.... too much gas!... WAY rich. You give it gas and it bogs or stalls... you let it run and it will stall on its own within 20 seconds. Mess with mixture screws and nothing happens. Im starting to think im actually missing a mixture screw somewhere. ...
PostPosted: Fri Jun 14, 2013 2:20 pm
You have probably damaged the fuel inlet needle and seat by installing them backwards. Crushing the tip of the needle ruins it and completely disrupts the float setting. Get a new needle and seat, check your float level, check the metering rod setting, and try again.
PostPosted: Mon Jun 17, 2013 8:02 am
There is not a curse on the truck...what you are experiencing is normal for an older model vehicle that hasn't been taken care of. I'm going thru it with my 84' D150 and it just takes time, patients, and learning about how to set the truck up so you have a nice older model vehicle :)
Just give yourself time to steadily work it into better shape and try not to get frustrated...once your able to get the motor where it starts and stays running and work some things out you may end up with something that still has a lot of miles left in it, that you can use a be proud of in time
PostPosted: Mon Jun 17, 2013 8:22 am
Ok serious question. Let me start off with explaining why I messed with the valve. I knew something was missing or odd after I unscrewed the fuel line from carb. Just looked different. Turns out the plastic cap that covered the fitting with the hole in the tip for the valve was missing... I found it stuck inside the threads pushing the floats. I cannot find a new duel line fitting ANYWHERE. .. I would love just the plastic cap bit no local parts store or dealership has the fitting. .. help?
Users browsing this forum: Bing [Bot] and 5 guests
