It is currently Sat Nov 28, 2026 6:22 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
 Post subject: No.
PostPosted: Sat Jun 15, 2013 7:38 pm
yank these new cam bearings that were just installed, and install a set of correctly-oversized cam bearings,
Actually I have rarely seen cam bearings needing to be resized unless the machinist installed them in the wrong order. Technically the cam journals don't wear as bad as cranks, and lifters/lobes. So you probably can keep your current bearings. The cam regrinder will just regrind the lobes and go from there. The problem with just plug and playing the cam now is the rust and repolishing of the wear patterns, best case scenario it actually works for a while and nothing happens until you lose a lifter or lobe, worst case scenario is the lifters and lobes just flatten out and you end up rechanging the cam and lifters and cleaning the coffee grounds out of the oil pan. If it were a matched set you'd clean the cam and lifters keeping them in order and reinstalling them. Too bad someone doesn't have a leftover SPD-3 stock replacement cam from their engine rebuild kit, that'd be the quick and easy. Price lifters accordingly per above, make sure to factor in the cost of shipping to determine a "good buy".
 Post subject: Re: No.
PostPosted: Sat Jun 15, 2013 9:51 pm
If it were a matched set you'd clean the cam and lifters keeping them in order and reinstalling them. ".
Yes, I had to clean the cam but the polishing of the rust off was an extremely light wire brushing with a 'fine' brass wire brush, so I shouldn't have polished off much at all: the rust was mostly dust. I did keep all the lifters labeled and in order, so I know exactly which lifter goes with each cam lobe. Why would the cams flatten out now, with having the cam tanked and cleaned? Are you talking about noticing something within the first 5-10K new miles of driving, or potentially something beyond the 25,000-50K mark?
PostPosted: Sun Jun 16, 2013 1:07 am
Car Model: 1964 Valiant V200
Cam bearings do not get re-ground, it's the lobes that get reground. So other than the problem your machinist had with aligning the cam bearing oil holes, you can keep those bearings.
Like everything else it's a gamble. You might get 1 mile, you might get 10,000. But either of the cases DusterIdiot wrote above result in you removing the engine to swap cams and clean out the oil pan.
PostPosted: Sun Jun 16, 2013 3:55 am
If you stripped the engine to fix a specific problem then maybe just fix whatever it was and reassemble it and take your chances,and it is a chance.If you stripped it to rebuild it back to a decent condition then I would suggest you inspect the engine thoroughly and do work out the cost,looking at the cam it's likely done a few miles so possibly a rebore,new pistons,head rebuild and of course a cam grind would be the big ticket items.If you reuse that cam on a rebuilt engine take note of how long it took you to do the job,and how much it cost,then multiply it by two,because you will be doing it again at some point. Even your guy who didn't do the cleaning correctly rightly assumed the cam as trash and left it outside,that's not the right thing to do,but it shows that even at his standards the cam was considered no good.
PostPosted: Mon Jun 17, 2013 5:14 am
Egge both stock new cams and lifters, as well as regrinding cams and resurfacing lifters.
Olaf
Aspenized
PostPosted: Sat Jun 22, 2013 8:04 pm
Well, thanks for everyone's opinions and help on this. I did try to resolve my cam bearing issue with my machinist, but unfortunately was unable to get him to correct his error without more $ outlay on my part. Therefore, I would not recommend people use Valley Auto Parts & Engines in Sun Valley. Oh well. However, I was able to solve the problem of the out-of-place cam bearing by egging out the bearing hole using a Dremel and smoothing out some of the rough edges using very fine grit oiled sandpaper. Thanks for the advice from DI and Doc, about how to rectify this, I appreciate it.
And after many comments and much advice prodding me to re-grind the cam, I did drop it off at a shop called American Custom Cams out here in Glendora, used to be called American Cam. Owner is quite familiar with the slant six cams, and recommended some very minor and gentle cam lobe adjustments from stock to "help the engine breathe a little better," but nothing more major than that. Looking forward to seeing his grind recipe. Should be getting that back soon.
 Post subject: bad service
PostPosted: Sun Jun 23, 2013 9:18 am
Your letting this guy off to easy.
Fast is fine but accuracy is final. You have to learn to take your time ... in a hurry
- Wyatt Earp
PostPosted: Sun Jun 23, 2013 9:48 am
Post up the cam card when you get it. Curious what they give you. I should call them and see if they have a lobe list.
