It is currently Sun Nov 29, 2026 9:27 pm
Post new topic  Reply to topic  [ 64 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Wed Jun 12, 2013 5:28 pm
Online
Site Admin
Yes we can help, and there are online calculators. If you have any questions about making the measurements, check here so we can walk you through it. Remember that a simple valve grind can change the number, so make sure you have good valves and guides up front. That way the math doesn't go out the window.
To measure CC's, you will need to have the head removed from the engine.
You know those old CD cases with clear plastic lids? That's what I use! :lol:
Install the spark plug in the combustion chamber your going to test. put a thin coat of grease on the head surface surrounding the combustion chamber. The plastic, whatever stiff flat piece you decide to use must completely cover the combustion chamber. Drill a couple holes in the plastic. (do that before you put the plastic on the head!)
Using a big Horse syringe, of 60cc size or better, fill it to maximum line with water. put the plastic over the combustion chamber, chamber up, and make sure it seals to the grease. fill the combustion chamber with water until all bubbles are gone, but don't overflow out the other hole. (There to let air out.) determine how much water is left in the syringe. Subtract that from the full amount.
Make sense? :shock:
Somebody double check me and make sure I didn't skip over anything! :lol:
CJ
PostPosted: Wed Jun 12, 2013 5:38 pm
6 Pack Dart
Make sure the head is somewhat level (slightly higher on the side with the vent hole in the plastic).
Richard
PostPosted: Wed Jun 12, 2013 5:41 pm
Ok simple enough! Ill do that tomorrow! How will I determine the year? Im pretty sure its a 63.
PostPosted: Wed Jun 12, 2013 5:42 pm
And its a 225. I plan to go 30 over.
PostPosted: Wed Jun 12, 2013 5:43 pm
My engine cover says Super Six? How can I tell that it is?
And what makes it different?
PostPosted: Wed Jun 12, 2013 6:12 pm
Online
Site Admin
Year: Check on the top of the block.(Deck) There is a pad that sticks out under spark plug number 1. It may have a stamp there. Clean that area and see if you have anything there. That will tell you quite a bit.
Barring that, how many shake out plugs are there on the driver's side of the block? (Freeze Plugs.)
Have the cylinders measured before boring. If it doesn't need to be bored, don't do it. The increase in cubic inches is negligible. Likely not even noticeable. Keep it standard unless you are correcting for wear.
If it is a super six, the carburetor on it will be a two barrel. Like the Carter BBD. Take a few photos of your carb, post them to your photo hosting account, then link them here. If you have a Super Six, don't mess with the four barrel. A SuperSix will perform better on a near stock engine than a four barrel generally will.
CJ
PostPosted: Wed Jun 12, 2013 6:17 pm
It had a 2 barrel on it but I could never get it right. That was 5-6 years ago. I put a one barrel on it then. And ran great until Sunday... Will the numbers or stamp tell if it was a true Super Six? And what was the difference between a Super Six and and stock 225? If the is 3.4 what can i get away with as far as wear?
PostPosted: Wed Jun 12, 2013 6:49 pm
Online
Site Admin
Super Six was a marketing thing. Two barrels weren't available on slant sixes until much later. If you are looking at an early engine, it didn't come with it. Did you find the stamp pad? The number of freeze plugs on the side?
What year is the car? '63?
What color is the block painted?
CJ
PostPosted: Wed Jun 12, 2013 7:35 pm
I'm not home. I will let you know how many freeze plugs and stamp when I get home. The block was orange. The car is a 63 Dart GT convertable
PostPosted: Wed Jun 12, 2013 7:41 pm
I called home and there are 5 freeze plugs on the driver side.
PostPosted: Wed Jun 12, 2013 8:32 pm
0225r 5 28 F
PostPosted: Wed Jun 12, 2013 9:07 pm
If you're having issues tuning a 2bbl, I would not suggest a 4bbl upgrade. Stay away from headers. Waaaaaayyyy too much trouble for minimum gain. Give your money to Dutra, its a better design and he deserves it more.
70 Plymouth Valiant 4dr
PostPosted: Wed Jun 12, 2013 9:13 pm
Online
Site Admin
:lol: Well, it ain't a '63 with five freeze plugs!
Not sure what the 0 on the front is for. Might it be a G?
Anyway, it's a '71 (G) May 28 build, Regular fuel.
I'm lousy with decoding. Hopefully somebody with the proper decoder ring will step up. :D
CJ
PostPosted: Wed Jun 12, 2013 9:28 pm
Tuning a carb isnt hard..there was something wrong with that carb. Put another two barrel on it ran great but i just didnt want to jerry rig the cable.
PostPosted: Wed Jun 12, 2013 9:31 pm
Could that be a 71 head?
