It is currently Sat Nov 28, 2026 4:20 am
Post new topic  Reply to topic  [ 37 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Yep...
PostPosted: Tue Jun 18, 2013 10:41 am
The port at the top of your picture is the PCV valve port.
That's a correct hook up, it looks like Holley has now omitted the 1/8" accessory nipple on the opposite side fo the carb under the fuel bowl.
If you don't want to mess with the manual choke, there is a holley retrofit electric choke kit that will screw right on and you can adjust the setting by using a phillips screw driver (you can also "borrow" the same choke from any Holley 2 or 4 barrel and install with the correct cork gasket washers from a holley rebuild kit, FYI).
 Post subject: Re: Yep...
PostPosted: Tue Jun 18, 2013 10:47 am
honestly, Ill probably just hook up the manual choke after I resolve this issue. if I can find the retrofit at a price thats worth it, I will go for it. do you think the vacuum leak (having a bolt missing) could have caused it? or should I go about checking the timing?
1973 Plymouth Gold Duster
48,000 Original Miles
PostPosted: Tue Jun 18, 2013 10:53 am
Yes. The missing hold-down bolt can cause a large vacuum leak which creates a lean condition which can cause lean backfiring. Also, hooking the PCV port up to the breath will cause a VERY large vacuum leak, also leading to lean backfire. Put those two together and you have a VERY large vacuum leak causing lean backfire.
I think you should still verify your timing is correct. Even better still, take the time to use a piston stop tool to verify that the timing mark on the vibration dampener is correctly indicating the position of the crankshaft. I have checked three dampeners on three different vehicles now and none of them has been accurate.
PostPosted: Tue Jun 18, 2013 12:04 pm
Im in the process of messing with the timing.the PCV port is hooked to the carburetor, I just worded my sentence wrong. That hose was always hooked up correctly.
so whats the procedure for hand cranking? I understand that I need to line the notch/slit in the crank pulley with the hole/circle in the timing mark. but I don't line this up until both of the valves for the first Piston close, correct? I have the valve cover off, I have the spark plugs out, and I have the distributor cap off.
PostPosted: Tue Jun 18, 2013 12:17 pm
(1) Rotate the crankshaft in a clockwise direction by hand. If you have a solid fan you can usually rotate the crank by pushing down on the belt between the alternator and the water pump and using the fan blades as a lever. Pushing on the belt creates a little more "grip" by the belt on the alternator and other pulleys.
(2) Rotate the crankshaft until the intake valve on the #1 piston has opened and closed.
(3) Keep rotating the crank until the timing mark reaches TDC the first time after the intake valve closes. At this point both valves on the #1 piston should be closed. The rocker arms should be loose with no tension in the valvetrain on that piston. This is because the piston should be at TDC on the compression stroke and the lifters should be completely off the cam lobes.
PostPosted: Tue Jun 18, 2013 10:42 pm
and to line it up after reaching TDC, I just spin the distributor rotor by hand until it points at the the spark tower for cylinder #1? sounds easy enough. the rotor doesn't seem like it's too easy to turn by hand but I'll mess with it.
PostPosted: Tue Jun 18, 2013 11:53 pm
To reposition the rotor you will need to remove the distributor hold down bolt and pull the distributor out of the engine block until the distributor drive gear disengages from the camshaft and then reposition the rotor and reinsert the distributor. Be aware that the rotor will turn roughly 30 degrees counter-clockwise when the distributor is removed and vice versa when it is inserted.
PostPosted: Wed Jun 19, 2013 8:42 am
alright that isn't too bad. Im pointing the SKINNIER part of the rotor towards shock tower #1. Im hoping that the hold down bolt is easy to get to...
PostPosted: Wed Jun 19, 2013 8:45 am
The rotor turns clockwise and you will want to put the leading edge of the metal contact on the tip of the rotor as close the #1 spark plug contact in the distributor cap as you can. The contact is directly below the park plug tower on the distributor cap.
PostPosted: Wed Jun 19, 2013 6:48 pm
oh no, I understand that perfectly. I actually have a new distributor cap that matches my powdercoated intake and valve cover anyways so this works out well. I was just saying that getting the damn distributor off is going to be...fun.
 Post subject: Welll...
PostPosted: Wed Jun 19, 2013 6:58 pm
If you are replacing the cap anyway, take your old one and drill a 3/8"-1/2" hole between the center and #1 tower and install it on the distributor so you can accurately see where the rotor is and get it aligned properly before bolting it back down.... :wink:
PostPosted: Wed Jun 19, 2013 7:02 pm
Uhh, get a ratchet with a long extension and a 7/16 or 1/2 inch socket. Not that hard, really. I usually daisy chain three or four ten inch extensions onto the ratchet so I can loosen the hold down bolt while standing up.
PostPosted: Sun Jun 23, 2013 2:40 pm
quick update.
I bolted up the carburetor properly and checked the timing. there hasn't been a single backfire through the carburetor ever since it was bolted on. I plan on taking it in to get my exhaust put on either tuesday or wednesday. the only thing left before I drive it to the shop is carburetor adjustment. the car starts up every single time I want it to start but will only stay running when I give it gas. The idle adjuster can technically fix the problem but it makes the engine rev WAY to high when I 'fix' it via this method, so MY assumption is that the fuel level is too low. I haven't messed with the fuel level adjustment screw since I installed the carburetor so it probably isn't pumping enough fuel into the carburetor for a smooth idle. thoughts?
PostPosted: Mon Jun 24, 2013 4:32 am
its sort of bizarre because it stayed running when it had the vacuum leak but it was also making it idle higher so that could go back to the fuel issue. Im just not sure because I heard that you are supposed to adjust the fuel level with the engine running but if its not running to begin with, I am wondering if it COULD be something else.
PostPosted: Mon Jun 24, 2013 4:16 pm
after playing with the fuel level while the car was off, I am realizing that I am just about stumped. The fuel level was actually too HIGH (it started running down the sight hole the second I pulled the screw out) and now it is at the point where it only trickles down when the car is rocked back and fourth. like I said, I checked the timing and it seemed like it was pointing right at the position of the #1 spark tower. My carburetor DID just backfire though. It is also somewhat common for it to burp up some liquid gasoline upon start up. It will stay running as long as I keep the RPMs up fairly high (I didn't equip it with a tach yet so I don't have a figure to share). I guess that THESE are my biggest puzzles:
-even though the car only stays running when I pump the accelerator, I discovered that my fuel level was actually too HIGH as opposed to too low.
-my timing seemed to be fine but my carburetor backfired and its spitting out gas.
Users browsing this forum: Ahrefs [Bot] and 4 guests
