It is currently Thu Nov 26, 2026 8:23 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
 Post subject: Ouch...
PostPosted: Fri Jul 05, 2013 9:49 am
Both gears are shot and most likely the one on the cam... Replace the gear on the distributor and if the pump check looks good, you can replace the pump gear and save some time and $$$.
 Post subject: cam gear
PostPosted: Fri Jul 05, 2013 12:04 pm
The cam gear is definitely gone, I found chunks of it in the oil pan, all that's left is razor sharp edges. Any best practices for removing the old dizzy gear and installing a new one?
I'd be circumspect about using that oil pump again, it seems OK, but...
bg
