| oil pump failure? https://slantsix.org/forum/viewtopic.php?t=52411 |
Page 2 of 2 |
| Author: | DusterIdiot [ Fri Jul 05, 2013 9:49 am ] |
| Post subject: | Ouch... |
Both gears are shot and most likely the one on the cam... Replace the gear on the distributor and if the pump check looks good, you can replace the pump gear and save some time and $$$. -D.Idiot |
| Author: | '67 Dart 270 [ Fri Jul 05, 2013 12:04 pm ] |
| Post subject: | cam gear |
The cam gear is definitely gone, I found chunks of it in the oil pan, all that's left is razor sharp edges. Any best practices for removing the old dizzy gear and installing a new one? I'd be circumspect about using that oil pump again, it seems OK, but... bg |
| Page 2 of 2 | All times are UTC-08:00 |
