It is currently Fri Nov 27, 2026 4:48 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
 Post subject: Re: Lol...
PostPosted: Sat Jun 29, 2013 9:06 pm
(I actually have one like this in the motor in my brown duster.) I put a #10 nut that's about 3/16" thick under the spring-between it and the cap, and it oils really good with no problems...pretty good for a 1970's over 100-200K oil pump....
Ok that's interesting, this 6-bolt Melling I just wrecked has a nut in it between the spring and the cap, just like you explained. I assumed it was supposed to be there: is this someone's mod?
PostPosted: Sat Jun 29, 2013 9:10 pm
Site Admin
Probably. I have a 1/4" nut under my spring. Shim it to produce the pressure you need. Mine needed that much to make 50# for my 5000 rpm. (This was a new pump.)
10# per 1000 rpm.
CJ
PostPosted: Sat Jun 29, 2013 9:26 pm
Got it. Cool - thanks for that tip. Didn't know it. Should I do it on the new pump, or because it's new, will pressure be enough?
The gear popped right off the new Melling with the fancy puller. I guess that's why it's $70. I hope I use it more than just this once. Something I kept running into while using all these different pullers: some have the swivel cap and point on their middle finger, and others just a point, but most do not have a flat. The swivel-headed caps absolutely didn't work, the two pullers I tried with a flat-foot finger kept 'walking off' the center of the shaft. But the Posi-Lock puller had a tiny point (not so much of a point anymore) that grabbed the center shaft just well enough to keep it there.
Pump is in the freezer as I type, getting cold enuf to do the gear swap, while I heat the hardened gear up to slide on.
Jeez. Can't wait to fast-forward to the next time when I'll remember all this and do everything different....hopefully.
PostPosted: Sat Jun 29, 2013 9:37 pm
Sorry to hear about your luck. If it makes you feel any better my luck has gone the same way. Almost everything has been done twice and sometimes WAY more then that.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Sat Jun 29, 2013 9:39 pm
Site Admin
Check the pressure, then shim as needed.
My pump was new and needed it. The springs vary, and the machine surfaces inside can vary too. The spring can loose tension over time also. You may have to revisit the pressure at some point.
CJ
PostPosted: Sat Jun 29, 2013 10:06 pm
On checking the pressure, DD recommends in his build article to tap the boss on the oil gallery at the rear of the engine for a oil pressure outlet hookup. I chose not to do this for my own reasons.
The pump I just wrecked had an interesting setup: where most oil pressure switches are, this one had a T valve, where the switch was threaded into one end of the T, and the other was sealed off for...I guess if you wanted to hook up something to measure pressure here, you could.
Would you get an accurate system pressure read with a setup like that off the oil pump?
 Post subject: What's the...
PostPosted: Sat Jun 29, 2013 11:12 pm
I've done this, and pre-1967 blocks seem to have pad abotu 1-2" forward of the tombstone on the galley rail to drill and tap (some trucks in the 60's has this standard it seems).. on the later blocks there is no pad so it can be hit or miss on this mod...I did it to a 1976 block and end up "gooping" the base of the oil sending unit to keep it from weeping....
I'm going to go out on a limb here and given the information nut under the relief spring, and "T" plumbed into the idiot light passage...smacks of a previously purchased and modified pump that a former member or board reader may have purchased, modified then returned...a normal melling comes with the pump, gasket, and a pipe/hex plug stuffed into the idiot light sender hole.... :shock:
Yes you can, but I have had the misfortune to see where Melling has mis threaded the sensor hole and if you install the adaptor and T then install the idiot light and oil pressure gauge sending unit, it will be cockeyed toward the block and once you tighten down the assembled oil pump/T/Sensors it will contact the block and crack the T, so be careful (doesn't happen on OEM pumps- good quality even in the Iacocca years...)
[/quote]
PostPosted: Sat Jun 29, 2013 11:26 pm
Site Admin
It's a good place to tap in. Older blocks had bosses on the main oil galley at the rear of the block. Regardless, this is the pressure that is available to the bearings, where pressurized oil is needed.
I abandoned my Oil pressure switch to the dash light and installed an oil pressure sending unit. All the light could tell me was I'd destroyed the engine already. Factory gauges are questionably accurate, but more qualitative than quantitative. Having multiple devices tapped at this point can invite leaks. Keep it as simple as you can.
Pressurizing more than the rule, 10#/1000rpm can result in "flowing" the bearings. Excessive pressure will move material. In our case, 60 or 70 pounds is a bad thing for the bearings and the OP drive gear.
If your spinning 6800 rpm, then 70 pounds is where you want to be.
Failure to prep the bearing so oil can get out can result in oil overheating and boundary conditions. Premature wear can result. This normally becomes an issue after turning the crank for undersized bearings, or making radical modifications to the crank.
More trivia for you to ponder. :D
CJ
PostPosted: Sun Jun 30, 2013 10:09 am
Eatkinson
i'm glad you decided to do it yourself! when we met that first time you seemed a little hesitant, but i gotta tell you man, you're really figuring it out now.
70 Plymouth Valiant 4dr
PostPosted: Mon Jul 01, 2013 1:11 am
Here is my 2c.
A very good tool and one I dont know how I did without, is a shop press.
hundreds of uses on a car.(including oil pump gear removal/assembly)
You can pick up a little 12 ton press for a little over $100 now days.
Hes going well, but he is finding out that good help is hard to find.(other than here of course)
Its a daunting task to rebuild an engine the first time,and there will be tests along the way. just remain calm and do it right the first time ,because doing it a second time, cause you took a short cut the first time, is not much chop.
ie. dont use that pump,its too important to screw that up.
good luck and try to stay calm.
When it all goes pear shaped ,i like to swear a bit (well a lot) take a few slow deep breaths and walk away for a while.
Brendan.
1963 AP5 Valiant 225 PB 904 Stock except extractors & 2 1/4 inch exhaust.
1962 S series valiant 225 PB auto. factory every thing. Full restoration job.
Currently on hold till AP5 is on the road.
PostPosted: Mon Jul 01, 2013 6:10 am
My stock pump provides 45-50 lbs of pressure all the time. At idle it is maybe 30-35 when hot. Aren't pumps pretty cheap compared to a new engine?
Sam
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 7 guests
