| 1976 Plymouth Volare slant 6 https://slantsix.org/forum/viewtopic.php?t=52704 |
Page 2 of 2 |
| Author: | olafla [ Tue Jul 16, 2013 6:38 pm ] |
This happened before I had any manuals, and I saw no reason for the pump leak, but the previous owner had warned me about it, so maybe there was some pre-bent chassis parts! Olaf |
| Author: | DusterIdiot [ Tue Jul 16, 2013 7:05 pm ] |
| Post subject: | You might... |
You might be able to get the OEM 5/8" rotor pump out after removing the cover plate, it is pretty close. Pulling a 7/8" melling pump in the car requires that manuever after jacking it up to get it out...the M66HV pump is pretty much a pull the engine affair unless you let mongo pull it out... |
| Page 2 of 2 | All times are UTC-08:00 |
