It is currently Sun Nov 15, 2026 9:32 pm
Post new topic  Reply to topic  [ 163 posts ]  Go to page Previous 1 2 3 4 5 … 11 Next
PostPosted: Mon Sep 09, 2013 8:09 am
I like that design Tom, how long are the runners. Also, is the plenum flat on the bottom just as on top.
Also, in my second drawing that shows a look into the plenum thru the TB, you can see that the #3 & 4 runners cant have as big of a radius at the port entry as the other ports, so I was thinking to actually move them farther apart at the plenum end so a more equal sized radius could be placed on all of them at this end.
Yes top and bottom are flat with a taper to the outside cylinders. Next time I am over at Dad's I am sure he will let me measure the runners for you.
This will give you an idea on taper. Even though it is a 4cyl it has a nice shape. Also notice the nice bend at the inlet.
Nitrous cars are like old men on Viagra. Once the bottle is empty they are useless.
FJD
PostPosted: Mon Sep 09, 2013 9:50 am
Car Model: 64 Valiant
Going to throw this out and I could be off base but one thing I hear a lot of is how when you have everything right 1 and 6 are lean 2 and 5 and good and 3 and 4 are rich. Wouldn't having the throttle body at the front of the engine cause as similar issue with the rear cylinders?
I am not sure how to fix it but I have an idea. What if the first 3 and last 3 were grouped together and fed by say a 40mm entry passage and then from the passenger side of the motor fed from the larger throttle body that split the intake air to both the front and back half. I think this could potentially shorten the runners and provide more air at the same time. I am not a designer just shooting from the hip.
As Greg pointed out, this is not the case in a dry manifold. The injectors are now what delivers fuel to each of the cylinder and they are equally positioned well inside the runners at an equidistance from the valves, so the plenum is basically just a big aluminum breather that you bolt the TB to, and each runner is like a straw in a big punch bowl and will only draw in how much air each cylinder needs.
PostPosted: Mon Sep 09, 2013 10:12 am
Ed, thanks for the explanation of how the triple weber carb setup works.
Tom, I really am impressed with your dad's manifold!
Brian
Flyin' Brian
"Sixy Beast"
PostPosted: Mon Sep 09, 2013 10:14 am
Car Model: 1964 Valiant V200
Can't wait to see the prototypes!
I assume you will be using a Mustang TB flange?
PostPosted: Mon Sep 09, 2013 10:27 am
I haven't really patterned the TB after any specific one yet, so it can be made to fit most anything at this point. I have seen many generic ones on eBay, but didn't know if any of you guys had a preference as to what type or brand you might like to use.
PostPosted: Mon Sep 09, 2013 11:14 am
nice work here,, but for runner length,, have you considered making a two piece manifold,, mounted to the cylinder head would be one section, with the injector nozzels and with cast connector couplings,, the air box would be a free standing unit with matching couplings,, the purchaser would then insert lengths of silicone hose sections,, one could custom tune the length to about anything.
the coupling connectors would need good roundness and surface finish to prevent leaks.
there would need to be bosses on the plemum for mounting brackets...
may actually simplify the casting / cores...
PostPosted: Mon Sep 09, 2013 3:12 pm
I don't know if the silicon tubes would be up to the task of supporting the weight of the plenum plus the TB, then you might have rigidity issues with the throttle linkage trying to open the butterfly with only the boots supporting the assembly. I think one single part reduces it to the simplest form for both machining and casting. I believe several people have tried both the Offy and Clifford intake with TB and injectors with pretty good results, their runner lengths are probably suited well for most anything from stock to 300 HP maybe. Any thoughts on that?
PostPosted: Mon Sep 09, 2013 3:14 pm
I can not find the article anymore but they actually made it adjustable by using air horns inside the plenum. The top of the plenum was removable and you could mount different length air horns on the inside.
The air horns also helped with air flow into the runners.
Very similar to this but it was for an inline 6.
FJD
PostPosted: Mon Sep 09, 2013 6:40 pm
Something like that could work, I remember back in the 5.0 heydays a company made an intake similar for the 302 that had interchangeable length runners inside a removable top plenum like that. Is this something like you were describing DadTruck
PostPosted: Mon Sep 09, 2013 7:07 pm
getting the air intake divorced from the surrounding walls as shown in the tom drake photo really helps to reduce wall friction and improve air flow, the provision for adjustable runners is another kick that would let tuners have their way. That does add mfg cost, maybe should be considered as an option,, but one that ai would want.
The best advice is to develop a product that gets the buyer a competative advantage,,(cost vs performance),, (interchangeable length) if it works,, folks will be beating down your doors to get one. Indy Cylinder head has a multi top plate manifold, accepts a single 4 bbl, two 4bbs,,,, make some thing folks can tune to,, that way from a product stand point, if it does not work, it is the tune,,not the product that does not work,,, and if some one can figure a cam and runner length that runs really well,, every one wins.
PostPosted: Mon Sep 09, 2013 7:21 pm
There is an article somewhere on the net, where one of the Mopar engineers who designed the Hyperpak manifold, described the method they used to get the runner length correct. Unfortunately my PC's hard drive with 20 years of Mopar notes crashed, so I have no urls to that article.
Anyway, they used the sound frequencies made by rushing air in the intake runners at different rpm levels to find the optimal length, if I remember correct it was 13 inches long runners that delivered the most even power through the entire rpm scale. Take into consideration that this was for a carburetted intake manifold, so plenum volume and runner layout could influence the design, but it shouldn't be much off in any case.
BTW, the way some EFI manifolds look, you shouldn't believe that they work at all! I don't think you have to be very concerned about where the throttle body is placed, air moves from a low pressure zone to a higher pressure zone in a blink of a second anyway.
Nice work!
Olaf
Aspenized
PostPosted: Mon Sep 09, 2013 7:27 pm
This looks more like what DT was describing above.
This is an idea for better airflow into the runner without having a complete air horn inside the plenum.
FJD
PostPosted: Mon Sep 09, 2013 7:35 pm
Thanks Dad and Tom, the more I think about the adjustability of the different length velocity stacks inside the plenum for tuning, the more I think that even though more cost will be added to the product, the unlimited value the customer will be receiving for that added cost will be much greater. That way like you said, if it doesn't work its the tuner, not the intake.
PostPosted: Mon Sep 09, 2013 7:46 pm
http://www.autospeed.com/cms/search/ind ... &.x=0&.y=0
PostPosted: Tue Sep 10, 2013 8:09 am
In most cases, a radiused inlet on a flat panel - like the one Tom Drake posted - flows better than an inlet pipe, or even a tapered air horn, in a plenum. I suspect the plenums with internal horns are used for hood clearance.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
