| ignition https://slantsix.org/forum/viewtopic.php?t=53391 |
Page 2 of 6 |
| Author: | Reed [ Tue Sep 24, 2013 5:00 pm ] |
I don't understand your reluctance to convert to HEI. It is technically superior to the Mopar ignition and is actually cheaper and easier to install. If you are dead set against switching to HEI, then you will need to get a Mopar electronic ignition control "brain" and wire it in. It can be from any slant six or V8 car, truck, or van, but it would be easier to install if it came from a truck since the wiring harness would be closer to what you want. I will need to see pictures of the insides of the distributors to tell you if they are "lean burn" or standard electronic ignition distributors. Here are the engine compartment wiring diagrams for a 1984 Dodge van. The truck should be pretty much the same, except for the length of the wires: ![]() ![]() ![]() I have 1984 and 1983 Dodge van factory service manuals and can scan the standard ignition wiring diagrams if you want them. |
| Author: | 1930 [ Tue Sep 24, 2013 5:09 pm ] |
Quote: I don't understand your reluctance to convert to HEI. It is technically superior to the Mopar ignition and is actually cheaper and easier to install. If you are dead set against switching to HEI, then you will need to get a Mopar electronic ignition control "brain" and wire it in. It can be from any slant six or V8 car, truck, or van, but it would be easier to install if it came from a truck since the wiring harness would be closer to what you want.
I just googled Mopar electronic ignition control "brain and yes I have one of these mounted on the firewallI will need to see pictures of the insides of the distributors to tell you if they are "lean burn" or standard electronic ignition distributors. Here are the engine compartment wiring diagrams for a 1984 Dodge van. The truck should be pretty much the same, except for the length of the wires: ![]() ![]() ![]() I have 1984 and 1983 Dodge van factory service manuals and can scan the standard ignition wiring diagrams if you want them. I also had one of these mounted on the 84 firewall as well I believe....scratch that I know it was there and I still have it I will get the pictures for you and post them tomm evening. Thanks for the diagrams and the help. |
| Author: | Reed [ Tue Sep 24, 2013 6:39 pm ] |
Yay. If you do have the "brain" on the firewall then you don't have a lean burn controlled ignition. But verify that you don't have a lean burn controlled carb. |
| Author: | 1930 [ Wed Sep 25, 2013 2:32 pm ] |
I am curious what this is, it was bolted I believe under one of the nuts or bolts on head
| Author: | 1930 [ Wed Sep 25, 2013 2:34 pm ] |
This is two other within the harness that I am not finding a home for, maybe someone here will recognize them?
| Author: | Reed [ Wed Sep 25, 2013 2:38 pm ] |
Correct, a lean burn distributor.
| Author: | Reed [ Wed Sep 25, 2013 2:42 pm ] |
Those are the wiring plugs that would plug into the lean burn computer. THe lean burn computer would have been originally mounted on the air cleaner or near the battery.
| Page 2 of 6 | All times are UTC-08:00 |
